Question about Kyocera Mita KM-5035 Printer
How do i reset kyocera mita 5035 to factory defaults?
6ya staff
SOURCE:
Anonymous
  • 66 Answers
SOURCE: I have Kyocera Mita KM-2050
you need to get the i.p address of your scanner and access it from your browser.
on the bottom left of the command centre menu you will see SCAN TO PC  "destination" .
put your details in new screen. if you are using a static i.p address for your pc put that in.
if you are running dhcp you should use the host name of your pc
Posted on Mar 10, 2009
Anonymous
SOURCE: I need to reset ID Code on Kyocera Mita KM-5530
The solution is easy! Push the Default Setting/Counter button on the top right side of the keyboard. Press the the Managment icon on the diplay. Enter 6-4-8-2 on the keyboard and select the Managment icon in the OFF position. Close all windows on the display and you should be ready to go.
Posted on Jun 18, 2009
Anonymous
  • 157 Answers
SOURCE: kyocera mita j11 error code
On most Kyocera Mita copiers a J-11 code indicates a possible paper jam when paper is being fed from drawer #1, but sometimes a J-11 will be indicated when the paper fails to feed from the drawer. Check the paper stops and paper guides in the drawer and make sure that they are flush against the paper, also cleaning the paper feed and pick-up rollers with a rag dampened with just plain water will help sometimes unless the rollers are completely worn out. If all this doesn't help you may have a paper feed clutch or lift motor that has failed.
Posted on Sep 18, 2009
shawn38
Shawn
  • 200 Answers
SOURCE: Service code for this printer came up C6000 what
This is a fixing unit error. If you have had a power outage or your power has flickered it maybe able to be reset with out parts. Go to www.gfbm.net and call thier number and they should be able to reset it over the phone at no charge.
Posted on Feb 19, 2010
ath10
Athi Lingam
SOURCE: Kyocera Mita Kyocera FS-1028 MFP Laser Print -
printer is working but scanner is not working
Posted on Jan 21, 2012
Kyocera mita error 630
reset fuser error , via service mode
Jul 09, 2014 | Kyocera Mita KM-5035 Printer
Kyocera Mita 5035
Go through the maintenance procedures in your manual. All cleaning should be done which probably includes roller cleaning but you should run it through all the procedures.
May 01, 2014 | Kyocera Mita KM-5035 Printer
Error code c6020
you need to reset the fixing unit. go to mode and input 163 then start off then on.
Feb 28, 2014 | Kyocera Mita Office Equipment & Supplies
Kyocera mita km 5035 image cycle problem
Ensure that the filters are not blocked and that the machine has sufficient air flow around the machine.
Sep 13, 2013 | Kyocera Mita Km 3035, 4035, 5035 Fs9120dn,...
Kyocera mita 5035 eror code c6000
i have kyocera mita this machine toch screen is working but numbers manual is not working please give me solution immediately
May 26, 2012 | Kyocera Mita KM-5035 Printer
Solution of error code 7410 for kyocera mita 5035
When Your Kyocera Mita KM 5035 Indicates Code 7410, It's the problem with your Drum Unit Or Drum. You Can Solve This Problem Either By Changing If You Have Another Drum Or Buy A New Drum Unit.
May 23, 2012 | Kyocera Mita Km 3035, 4035, 5035 Fs9120dn,...
C7400 error kyocera km 5035
Error C7400 on Kyocera km 5035 is Image formation unit problem or connector
Hope this will help
Feb 14, 2012 | Kyocera Mita KM-5035 Printer
Feb 18, 2010 | Kyocera Mita KM-5035 Printer
Kyocera Mita KM-5035 Printer Logo
560 people viewed this question
Top Kyocera Mita Office Equipment & Supplies Experts
Adorjani Laszlo
AAAA262430
Marvin
Marvin
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
