I am having problem with my iphone 4 My problem is as follows my iphone 4 wont turn on it keep shuting down after showing apple logo repeat and repeat please help thanks
IPhone Flashing Apple Logo Three Solution to Fix it
That might perplex us for a long time and we have to find a solution to get our iPhone back. Therefore, here I'd like to show you three effective ways to fix iPhone 6 flashing apple logo issue.
This must be the easiest way to fix the iPhone flashing Apple logo problem, but the only problem with this process is that it often results in total data loss and hence presents a problem if you didn't have a backup of the data on your device.
Use this help from apple to restore your iphone:
If you can't update or restore your iPhone iPad or iPod touch
SOURCE: my iphone 3gs has hung at the apple logo. reset,
Make sure you have the latest version of itunes on your comp & power up comp & itunes
-power off your phone
-hold
down the home button (around 6secs) then insert USB cable while still
holding button then release button when cable plugged in
-itunes will then bring up message saying that the phone has been detected in recovery mode
- it will then give you choice to restore your iphone
-continue
with this choice & restore your phone, you can either restore as a
new phone (like new) or from a back up (all your stuff back), try from
your back up first, if this doesnt work and you go back to square one
then do this process again only this time restore your iphone as new and
resync your info later on.
Hope this helps!!
SOURCE: hey guys, i have just opened my Iphone 4 box and
Hi Hamada2f, Try holding the power button and home button at the same time for around 10 seconds or till the apple logo appears on the screen.
SOURCE: How do I insert a SIM card into My APPLE 4 IPhone
There must be a sim card slot in its' back, take out the battery, you can find it.
electronics wholesale
SOURCE: iphone wont shut down
if all else fails you have apple care for 1 yr covered for defects... 2 yr if you bought apple care plus...... and or 30 days to return and swap phones where you bought it from
TRY THIS
http://blog.laptopmag.com/5-reasons-you-shouldnt-upgrade-to-the-iphone-5
If iPhone won't turn on, or the display freezes or doesn't respond
More resets:
Try This:
1. Remove Sim Card
2. Hold in 'Home' button and 'On/Off' button together until Apple logo appears
3. Replace Sim Card
4. Hold in 'Home' button and 'On/Off' button together until normal phone screen appears.
Also, Try this:
1.) Shut down the iPhone 3G.
2.) Start up iTunes
3.) Hold down HOME button on the iPhone 3G
4.) While keeping the HOME button depressed, plug in the Sync cable
5.) A message will pop up to ask if you want to reset.
6.) Just click YES and the reset process should start.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays! Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Download the latest iTunes to your computer and reset the iPhone. Then re-sync it.
Reset
To reset iPhone, press and hold the Sleep/Wake button and the Home button at the same time for at least 10 seconds. During this time, a red "power off" slider may appear and the screen may go black, but do not release Sleep/Wake and Home buttons until the Apple logo appears.
More resets:
Try This:
1. Remove Sim Card
3. Replace Sim Card
Also, Try this:
2.) Start up iTunes
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Thanks, Joe
