Westinghouse Electric LD4255VX 42 42 LCD TV Logo
J
John Olafson Posted on Apr 28, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Manual for LD-4255VX
How to setup an antenna? I have connected the antenna but I am still not getting a signal.
Level 3:
Top Expert:
  • Westinghouse... Master 76,851 Answers
  • Posted on Apr 29, 2014
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
15007224
Points
237762
1helpful
2answers
Wondering if its my main board on my hdtv flat screen. it comes on normal for about 10 to 15 seconds then i lose video but not audio
sounds like a failing t-con board. this board is on the back of the screen controls the signals to the screen. ribbon from main board goes to the t-con board.
I have a Westinghouse LD-4255VX 42 tv and when I turn it on the screen comes on with the crown symbol and then it cuts off
Fault with main board. Damaged component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too will be necessary.
How do you get to channel 60 without going through the set-up menus on the Westinghouse LD-425 series
maybe you need the dvr or their box and use that into input (channel 3 or 4) and use the remote.
Really? cool... so I have a Panasonic HDTV 720p... just moved, no cable, but I have a TV antenna. Amplified indoor antenna. GE brand model 24700. I powered and connected the coaxial cable between the tv...
You need to go into on screen TV tuner/channel scanning setup page and change the signal source from CABLE to ANTENNA so it will scan again to pick up off the air signals. Please read the TV user manual for more details.
What is the model number of the TV?
Code for led TV ld -4255vx
Hello Pajin, if you are looking for remote codes on this specific model, try using the Sony codes. If you need any further information on this model # please feel free to send me a quick email to [email protected], please rate my response if it was helpful.
Setting up antenna to television
For setting it your set you will have to connect the antenna to the back of set.
Go into the setup menu to select the input signal source.
Set the signal input to the antenna air.
Go to the scan section of the setup menu.
Scan in the channels. You can move the antenna and re-scan to try to get more channels.
Exit menu.
Now you can watch.
2helpful
Trouble with Channel setup
It is important for the TV to know what type of
signal-Cable TV (CATV) or a normal antenna
you are using. Choose your signal (Antenna or
Cable):
Press MENU to see the main menu.
Press CH+ or CH- to highlight Setup.
Press OK
to enter the Setup submenu.
TV/CATV is highlighted. Press VOL+ or
VOL-
to select TV or CATV.
Choose CATV if you have Cable TV
service. (See page 4 for connection
details.) If you do not have Cable TV
service and you connected an antenna
to the TV, choose TV. (See page 5 for
connection details.)
Press MENU repeatedly to exit the
menu or the menu will automatically
disappear within a few seconds if no
buttons are pressed on the remote
control.
And here is the manual if you need .
http://tv.rca.com/RCATV/Assets/pdfs/27F520T_1641312E_IB_e-06.pdf
Good luck and please rate
2helpful
17 in. trutech tv unable to get channels except 2-13
For channel setup you will need to;
1) Connect the signal source to the back of the set.(Antenna or Cable)
2) Go into the TV Menu and select the same signal source you connected to the back.(Antenna or Cable)
3) Go to the auto program/scan menu and run it. This may take a few minutes.
Now the channels may be watched.
Top Westinghouse Electric Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
Are you a Westinghouse Electric Televison and Video Expert? Answer questions, earn points and help others
