SOURCE: Black line on document when I scan from platen or ADF or scan to save as PDF.
This won't help fix the problem, but we get the same black line when printing from the pc. It looks like one of the black inks has leaked into the bottom tray (paper exit) just the front side of the rollers as there is a huge smudge there. No idea where it comes from. Tried to clean it up but seemed to come back. ??maybe the ink leaks from the cartridge or somewhere below the cartridge???
SOURCE: how to scan documents then email them
To scan and send the documents via. e-mail. First of all you must run the setup from the cannon cd (comes with printer), use full installation (recommended option) complete the installation.
If this is already done then :-
1] Put the document that you want to scan in the scanner,
2]Open "control panel" and open "scanners and cameras" folder. (switch to classic view if needed)
3]Switch on the printer (if it's on only then proceed to next step)
4]You will see your scanner icon (if necessary refresh the screen)
5]Open it and click "next"
6] (OPTIONAL) Select scan image type.
7]Click "next".
8]Choose a place to save your image.(default is my pictures)
9]Click "next"
10]and now image scan starts, at last click on finished.
11]Now open your e-mail account, choose "compose mail" fill in the details
12]now select "browse" (for gmail) or select upload file
13]select the address of the image where you saved it (default my pictures)
14]click ok.(you can only upload 1 file at a time)
15]send the mail. !!
16]Thus, you can send image by scanning like as stated above .
SOURCE: My MX-300 Printer prints only code when printing documents from
There are a couple of things to try at this link.
SOURCE: Canon Pixma MP150 offline - won't print from computer
hi,
CANON PIXMA MP160 All-In-One InkJet
Printer has few common problems. Such as Driver CD
lost, Scanner does not work, Connection problem etc. For find all these software solution
just click here....
http://www.canon.com/printer/prob676ijt65/solution
tokio-25
SOURCE: My canon MP40 will not scan/copy
This is because you have NOT installed the actual Drivers for the scanner and the Scan Manager. Driver link below. Ensure you get entire package A:SO get the user manual, it shows you what to do.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=123&modelid=15603
