Exposure lamp problem
When input value at the time of exposure
lamp illumination does not exceed the
threshold value between 5 s.
Check the connection of connector YC5 on
the ISM PWB and the connector on the
inverter PWB, and the continuity across the
connector terminals. Repair or replace if
necessary.
Defective exposure
lamp or inverter
PWB.
Replace the exposure lamp or inverter
PWB.
Incorrect shading
position.
Adjust the position of the contact glass
(shading plate). If the problem still occurs,
replace the home position switch.
Defective PWB. Replace the ISM PWB, ISC PWB or CCD
PWB and check for correct operation.
SOURCE: KYOCERA MITA KM-1500 ERROR CODE C7980
C-7980 - Means that the waste tonerresevoir in the process unit is full with less than 100,000 copies onthe unit.
Clean/ empty the waster toner and vac.Also clean the sensor.
You may have to change the Process unit if cleaning does not work.
SOURCE: I need to reset ID Code on Kyocera Mita KM-5530
The solution is easy! Push the Default Setting/Counter button on the top right side of the keyboard. Press the the Managment icon on the diplay. Enter 6-4-8-2 on the keyboard and select the Managment icon in the OFF position. Close all windows on the display and you should be ready to go.
SOURCE: Scan error C3200
remove the flat wire in the scanner, then remove the railings from the scanner, clean the railings with a soft cloth, if you encounter the c3200 error it only means that the railings of the scanner is dirty, the scanner cannot move. i hope this will fix your problem..... if you have anymore questions regarding kyocera copiers dont hesitate to txt me or call me to this number +639081953003 or +639079941995
SOURCE: kyocera mita j11 error code
On most Kyocera Mita copiers a J-11 code indicates a possible paper jam when paper is being fed from drawer #1, but sometimes a J-11 will be indicated when the paper fails to feed from the drawer. Check the paper stops and paper guides in the drawer and make sure that they are flush against the paper, also cleaning the paper feed and pick-up rollers with a rag dampened with just plain water will help sometimes unless the rollers are completely worn out. If all this doesn't help you may have a paper feed clutch or lift motor that has failed.
