You can download the audio and device drivers from the Compaq/HP WEBsupport/download page. Make sure you select your model laptop and the Windowsdrivers you require and install them. Click on this link to download thedrivers: - http://welcome.hp.com/country/au/en/cs/support.html
You can download the video and device drivers from the Compaq/HP WEBsupport/download page. Make sure you select your model laptop and the Windowsdrivers you require and install them. Click on this link to download thedrivers: - http://welcome.hp.com/country/au/en/cs/support.html
You can download the device drivers from the Compaq/HP WEBsupport/download page. Make sure you select your model laptop and the Windowsdrivers you require and install them. Click on this link to download thedrivers: - http://welcome.hp.com/country/au/en/cs/support.html
You have to go to hp website www.hp.com/#support go to start control panal and click on sound make sure that it is not muted ,if not remove and reboot computer and vista should reinstall sound drivers
Install the sound drivers...
probably you have a conexant audio solution.
Install Microsoft UAA BUS DRIVER FIRST.THEN INSTALL CONEXANT AUDIO DRIVER FOR YOUR LAPTOP. THE DRIVERS CAN BE FOUND AT HP SUPPORT SITE.FIND YOUR MODEL NUMBER AND DOWNLOAD YOUR DRIVERS
1) There is SD card reader on pavilion dv 1000, so you need adapter in which you insert mini SD card to make it SD 2) If you have that adapter, check adapter. Maybe it's broken. 3) If your card is biger, like 2GB or higher you may try updatenig drivers (I read on one web page: "
There was a software update for support of reading and using higher memory SD cards, for my pavilion ZV5000, on the HP Software update website." )
I have the same described problem above.
i have the same problem
bot were i cant fine the same driver for windows vista
after formatting i cannot install the sound driver
gosh!
i download a driver but he no work
can't install my sounddriver after reprograming my computer
