Televison & Video Logo
A
Anonymous Posted on Apr 28, 2014
Samsung ln 84041d
What is a comparable Samsung tv to the LN 84041D. I need to replace that for my father without him knowing> Long story-please advise.
1 Related Answer
Anonymous
  • 10594 Answers
  • Posted on Jan 15, 2011
SOURCE: i have a samsung ln-84041d
There is Automatic Volume Control option available in Samsung LN-S4041D lcd tv, to access auto volume control, follow below procedure.
Press the MENU button to display the menu, press the up or down buttons to select "Sound", then press the ENTER button, Press the up or down buttons to select "Auto Volume", then press the ENTER button, Press the up or down buttons to set Auto Volume "On" then press the ENTER button.
Press the EXIT button to exit.
This option will control volume level when you change channels.
Hope these info will help you.
Thanks.
2answers
Samsung LN-S2651D LCD TV no picture
What happens when you turn the TV on? Is there a clicking noise or popping sound?
tip
Input Switching issues Harmony Remote and Samsung TVs
The following 2008 Samsung TV’s have Anynet+:
LCD
All 9 Series LCD TVs (LNxxA950)
All 8 Series LCD TVs (LNxxA850, LNxxA860)
All 7 Series LCD TVs (LNxxA750)
Most of the 6 Series LCD TVs (LNxxA650, LNxxA630) excluding the 19” and 22” models
All of the 5 Series LCD TVs (LNxxA550, LNxxA540, LNxxA530)
Most of the 4 Series LCD TVs (LNxxA450) excluding the 19”, 22”, and 26” models
Plasma
All 7 Series Plasma TVs (PNxxA750, PNxxA760)
All 6 Series Plasma TVs (PNxxA650)
All 5 Series Plasma TVs (PNxxA550, PNxxA530)
Half of the 4 Series Plasma TVs (PNxxA450) excluding the 410 line (PNxxA410)
DLP
All 7 Series DLP TV’s (HLxxA750)
All 6 Series DLP TV’s (HLxxA650)
All 5 Series DLP TV’s (HLxxA510)
2007 Samsung TVs With Anynet+
The following 2007 Samsung TVs have Anynet+:
Note: Excluding all 26" models and below.
LCD
All 81F series (LN-Txx81F)
All 71F series (LN-Txx71F)
All 65F series (LN-Txx65F)
All 61F series (LN-Txx61F)
All 53H series (LN-Txx53H)
Plasma
FP-T5084
FP-T6374
HP-T4254
HP-T4264
HP-T5054
HP-T5064
DLP
All 89S series
HL-Txx89S
HL-T7288W
Information on Samsung TVs that support AnyNet has been refered to from: http://ars.samsung.com/customer/usa/jsp/faqs/faqs_view.jsp?isARS=Y&SITE_ID=1&AT_ID=18104&ARS_ID=8514159
How To Disable Samsung Anynet+ so your Harmony Remote Control properly controls your devices. This mainly impacts Input Switching.
1) Press your Tools Button.
2) Scroll down to Anynet and press your Select Button.
3) Once on the Anynet screen, please press your Left/Right Button(s) to select the Off Setting on the Anynet+ (HDMI-CEC)
4) Scroll down to the Auto Turn Off and select No.
Once this is completed, please turn off your TV and all device and power them back on using the Harmony Remote. Also please test this in the Activities mode, if this does not work, let me know
46" LCD Samsung TV Model# LN-S4692D I have no picture
The back light inverter board may have gone out or it is not getting the 24vdc from the power supply module. Start checking for voltage feeding the inverter board.
Parts: http://www.shopjimmy.com/catalogsearch/result/?q=Samsung+LN-S4692D+
2answers
Can I replace a blown speaker in the Samsung LN-s4051d? If so, how?
You have to take the TV rear panel out and just install a new one, you can get it here.
http://www.shopjimmy.com/catalogsearch/result/?q=Samsung+LN-S4051D+
Are you sure the speakers are bad, not the amplfiers?
Samsung LN-T1953h audio not working correctly
It sounds like the headphone jack may be going bad. I do not know how to replace it, but if you can find BN94-01208C fits LNT1953HX all you have to do is swap out the main pcb with the new and you have a working tv agin.
I own a samsung ln-84041d,and I have noticed lately that the tv is very slow to start-up,,I have it plugged in an outlet that is always on,,and it is running through a brighthouse HD cable box for the...
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; [Exclude the model number], in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
2helpful
2answers
Samsung LN-T5265F
Samsung LN-T5265F S POWER SUPPLY UNIT BN44-00150A
Green color on Samsung ln-t4042
If the whole screen has this tint problem, there is nothing you can do. It must be repaired. You will need to take it in for service.
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
