Intuit Error 15243
QuickBooks Error 15243
by
Dylan on January 27, 2019 in
QuickBooks Help 0
QuickBooks Error 15243 Overview
QuickBooks error code 15243 usually pops up on the screen when the user is trying to update QuickBooks Desktop or is downloading latest payroll update.
QuickBooks error 15243 may also show up when exporting transactions to excel. 15XXX series is very common series of errors in QuickBooks desktop. Usually, users get it fixed by applying simple troubleshooting steps provided by experts. The ugly thing about errors like QuickBooks error 15243 is they affect the workflow. Sometimes users get stuck in resolving these errors on their own. In these circumstances, users should get in touch with QuickBooks tech support experts to resolve their concerns quickly.
Causes of QuickBooks Error 15243
The various causes due to which QuickBooks error code 15243 occurs are mentioned below:
·Incorrect QuickBooks installation
·Intuit QuickBooks File Copy Service (FCS) is damaged
·QuickBooks FCS service is not enabled
·QuickBooks Payroll subscription has ended
·Damage in Company File
·User not logged in as an Administrator
QuickBooks Error 15243 - Intuit FCS Service is Damaged
QuickBooks Error 15243, while updating QuickBooks desktop appears on the screen stating
Error 15243: Intuit FCS Service is Damaged. This is because of the Intuit File Copy Service is disabled. Disabled FCS service is causing the error to update QuickBooks desktop. Intuit FCS service is an essential add-on service which manages file transfer during your
QuickBooks desktop update. Below-mentioned steps are troubleshooting steps to resolve
QuickBooks error 15243. Also helps when Intuit FCS is damaged.
Resolve QuickBooks Error 15243 in QuickBooks Desktop
·End all open QuickBooks windows and close the application
·Go to the
Start button
·Right-click on
Computer/This PC
·Choose
Manage option
·Go to
Services & Application Tab
·Double Click on
Services option
·When you see
Intuit QuickBooks FCS, click on it
·Click on the
General Tab
·Click on
Startup
·Choose the
Manual option
·Click on
apply
·Choose
Start & then
Ok
·Now, Reopen your QuickBooks as an administrator
·Open Company file & Update QuickBooks again
QuickBooks Error 15243 When Trying to Export to Excel
When QuickBooks user is trying to export workbook or worksheet to excel. He comes across QuickBooks error 15243. The reason for this problem can be the payroll subscription. To resolve this error go to Quickbooks Payroll account maintenance page to re-validate the payroll subscription.
Resolve QuickBooks Error 15243 in QuickBooks Payroll
·Open QuickBooks
·Go to the
Employees option
·Choose
My Payroll Service
·Select
Manage Service key
·Click on the
Edit option
·Verify your Payroll Service key
·Choose the
Next option & remove the check for Open
Payroll setup- I want to start right now
·Select the
finish option
·After the verification, Go to
Employees
·Select
Get Payroll Updates
Download Latest Payroll Update for QuickBooks Desktop & Update
Contact QuickBooks Support to Repair QuickBooks Error 15243
If above-mentioned troubleshooting steps for QuickBooks error 15243 doesn't help. Get in touch with QuickBooks support team by dialing +1800-316-0126. A certified team of professionals is available around the clock to help you resolve errors like QuickBooks error 15243.
Common Errors like QuickBooks Error 15243
QuickBooks Error 15271
QuickBooks Error 15215
QuickBooks Error 15101
QuickBooks Error 15214
QuickBooks Error 15203
QuickBooks Error 15222
QuickBooks Error 15262
QuickBooks Error 15102
QuickBooks Error 15106
Hi Anonymous, I want to help you with your question, but I need more information from you. Can you please add details in the comment box if your problem is still unresolved?
Include the operating system info. Did you post this on the QuickBooks community site to see if it a known error? Did you try re-install?
