I pulled the plug and waited 2 minutes and plug the fridge again. This reset the LCD of on MaytagI pulled the plug and waited 2 minutes and plug the fridge again. This reset the LCD of on Maytag
You can't post conmments that contain an email address.
Should find a video to test the compressor with a multimeter--this is the one I used. The compressor on mine was fine but the switch was bad--two dollars and some change, free shipping. Although mine was on a compact fridge the same components are present in your model. If the compressor is bad and this is a several thousand dollar fridge I would suggest having a professional replace the compressor for you.
You should replace you lcd soon to see the correct setting of appliance.
It is hard to control your freezer with out its screen working normal.
Regards,
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
freezer not working on ariston...
Solve
freezer not working on ariston fridge freezer 2 orange lights on top of fridge keep beeping every... (More) freezer not working on ariston fridge freezer 2 orange lights on top of fridge keep beeping every two hours causing fridge not to work is there a reset button
Is this a side by side fridge freezer? Most Whirlpool models with LCD display on front- reset filter indicator to display 99% by pressing and holding 'OK' button until filter resets to 99%. If you have a different model, or of this doesn't work, advise on model number and I can instruct further
Because this occurred as a result of a power outage, you need to check that the outlet is OK. Plug something in the outlet like a lamp and see that it works normally. If that is OK, check the display for a light bulb that is burned out--incandescant bulbs do that occasionally in a power outage. If it is an LCD or LED display, the power supply is bad on the display board. Is the motor humming and making normal noises?--and your freezer is just not cooling? If no motor noise, look for a reliable and trustworthy appliance repair person. If the damage is costly, try to pursue a claim with the power company.
Check the vents of your fridge side if present, if no air then may be your blower not working or some ice formation that blocks the air(try defrosting). Check also your vents for obstruction or overloaded with stocks.
