How can I unlock my proscan tablet I don't remember my swipe password and it has been swiped several times
try to soft reset it by engaging the reset button ..If it has such a button it should be hidden in a hole on the side and need to be pressed until restarts ..(it should be powered and on when you do this) ..
If there is no button ..it means it has something wrong with the touch screen function ...and you should try to see if the screen is not out of focus..and try to swipe it in a certain point ..and if it is indicated..try in near by locations ...If you manage to make it start you should look in the main menu for screen calibration ..and engage it ..this should make the touch screen work proper again .
In worse case you will need the firmware and reset it to factory settings ..
SOURCE: put a password into my acer tablet A500 now i canrt remember it and cannot use the tablet
you need to go to any repair centre to flash the tablet.if you can do it then try using phoenix
SOURCE: how to unlock proscan android tablet plt8015-k-b
To perform a factory reset, you will need to do the following: -turn of the tablet -press the following and hold: power button reset hole -hold until you see android logo screen -poke the reset hole to navigate to `wipe data` or `factory reset` -select using the power button -select delete all user data -restart the device -choose restart/reboot after reset This procedure will delete all apps and data on your table
