Dell OptiPlex GX520 PC Desktop Logo
A
Anonymous Posted on Apr 29, 2014
Cant show display
Just blink orange light what problem in desktop pc
Abhinandan Patil
Level 3:
Master:
  • Master 589 Answers
  • Posted on Nov 06, 2015
Abhinandan  Patil
Master
Level 3:
Master:
Answers
589
Questions
Helped
124131
Points
1347
Can you hear any beep sound from the pc?
if your desktop power coming on?
4 Related Answers
Teh_shivers
Mike Fish
  • 104 Answers
  • Posted on Dec 15, 2008
SOURCE: I have a system of
That is a memory failure 1 or more sticks of memory are malfunctioning, here is a link with all the information about the diagnostic lights as well as a beep code list
http://www.austincc.edu/cloud/manuals/Dell/GX260/solvprob.htm#1167139
nvnt28
  • 17 Answers
  • Posted on Jul 24, 2010
SOURCE: No display in my dell gx520 desktop pc only 2 and
hey you must check out if the wiring and plgs are properly connected,if after checking it still not works,then u must check out if the jacks are working properly.....coz in most cases the problem is with the jacks or the wires used.............at last u shld take ur screen to nearest repairing centre!!!!!!!!
Anonymous
  • 86 Answers
  • Posted on Sep 14, 2011
SOURCE: My Dell Optiplex 745 Desktop
The orange blinking on your desktop power button says that there's a problem with either the power supply or the motherboard itself.
Please refer to this link for the diagnostic lights on dell computers.
What you can do is: 1. unplug the power cord 2. press the power button, hold on it for more than 5 secs 3. re-plug the power cord on your CPU 4. test if it the system will work.
If this troubleshooting step does not help, that means it is more likely that the problem is with the motherboard.
Hope this helps!
rajasaad
  • Posted on Sep 16, 2013
SOURCE: Dell PC Desktop Optiplex GX260 Doesn't boot
i wana khow
about krst
Helloi am having problem with dell t5400 presionwhen i start my pc and show my desktop few minutesautomatically turn off and orange light blinking do you tell me what the problem with My t5400 precisi
The only blinking orange light is located on the Network RJ45 connection
If you're talking about the Power light on the Front panel:
If the Power light is blinking green the computer is in a sleep state: The computer is in standby mode. Press a key on the keyboard, move the mouse, or press the power button to resume normal operation.
If the Power light is blinking amber indicates that an internal power problem might exist; The computer is receiving electrical
power, but an internal power problem may exist.
Ensure that the voltage selection switch is set to match the AC power at your location (if applicable).
Ensure that all components and cables are properly installed and securely connected to the system board.
You can find the User Manual here Product Support Dell US
Zoostorm laptops
please read and execute the commentaries. God bless you
Charging Conventions
  • The majority of laptops will display a solid green, blue or purple battery light to indicate that the battery is fully charged. Most manufacturers indicate that a laptop is in the process of charging by displaying a solid or blinking green, orange, blue or purple light. If your battery indicator light is green, blue or purple, the battery is probably functional, regardless of whether the light is blinking. If the light is solid orange, the laptop is probably in the process of charging.
Battery Error Coneventions
  • Many battery manufacturers use rapidly blinking lights to indicate that a battery's charge level is low. In general, a laptop will rapidly blink orange or red when its charge drops below a certain level until the computer is plugged into a power outlet and charged. If your laptop's battery indicator continues to blink rapidly in orange or red or if it remains red even when it is plugged into the charger, it indicates a problem with your battery or the charger.
1helpful
Everything is not working, the monitor light is still orange
If your monitor goes off and your PC is running and monitor display has appeared. The sign of orange light shows that there is a fault in monitor. The solution is that provide the heat or sunshine to monitor for 2 hours and then your monitor work well guaranteed.
Good Luck
WHY DID'N START MY DELL DIMENSION 11OO ONLY BLINKID THE POWER LED
you have either one of 2 problems... your power supply is bad.. blinking orange light ??? or main board
try replacing power supply
is still blinking orange light then it is the main board
The power LED of my compaq monitor blinks when powered. Sometimes it works well but after 20 minutes display disappears and it blinks the power LED.
if the light blinks orange after a few minutes after use. The monitor would either require repair or replacement since the power board has gone bad.
Thanks
Proton
My HP Media Center m7330n won't power up... The fan comes on but will not boot.. The LED power light blinks at 3 second intervals from blue to yellow/orange.. What is the diagnosis...
You have to check with your RAM sir, if you know to remove the side cover of your CPU(tower) there will be a green colored chip fixed in vertical position in the motherboard if remove it and then fix it properly means you will get the display in yur screen.i will show you the RAM picture2f70f69.jpg
4helpful
The power light comes on as orange
REMOVE board from cabinet then check you can easily track the problem
1helpful
No display and wont boot
A Blinking Amber or Yellow power button means that the power supply is receiving power from the source but is unable to properly distribute it to the components. This can be caused by a defective power supply or a defective motherboard. Power supply is easier and cheaper to replace.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
