Casio DB360G-9A 30 Pages Telememo Watch Logo
A
Anonymous Posted on Apr 29, 2014
Reset time how to reset time
I bought a watch for my grandson. It had no instructions. It is from China MFG# FMDAW549. Are there directions available
Possibly these instructions:
http://forums.watchnet.com/index.php?t=tree&goto=110449&rid=0
DIGITAL WATCH USER INSTRUCTIONS May 27, 2006 - 05:59 PM On 5/26/2006 I bought from Walmart a $6.43 watch, on the back of which is written "AH 1175, 52, Battery CR2025, China Module, FMD, Base Metal Bezel, Stainless Steel Back, 100ft Water Resistant". It has no control buttons on top (where buttons may be accidentally pushed), the display is larger and more visible, and the color is dark, so I bought it even though I prefer models that have a fabric/velcro wrist-strap.
Four buttons on this watch are labelled: Light, Mode, Reset, and St/Sp. The instructions which I found inside its container refer to the Light button as A, the Mode button as B, the Reset button as C, and the Start/Stop button as D, but otherwise do not pertain to the watch, so I determined the button's functions by trial and error, as follows:
TO SELECT THE DISPLAY MODE
Push the Mode Button in order to select one of the following four display modes in the following order: Normal Time, Stop Watch, Alarm Reset, Time Reset.
In the Normal Time Mode, the Day of Week, the Hour, Minute and Second are displayed (none flash). If the Alarm and Hourly Chime icons are not displayed, the Alarm and Hourly Chime are turned off.
TO DISPLAY DAY OF WEEK, HOUR, MINUTE, SECOND AND WHETHER THE ALARM AND HOURLY CHIMES ARE ON:
Push the Mode button until no icon is flashing. The Alarm and Hourly Chimes are off if no Alarm or Chime icon is displayed beside the Second display.
TO DISPLAY THE DAY, MONTH AND DAY OF WEEK AND WHETHER THE ALARM AND HOURLY CHIMES ARE ON:
In Normal Time Mode, push the Start/Stop button. The Alarm and Hourly Chimes are off if no Alarm or Chime icon is displayed.
TO DISPLAY THE ALARM TIME
In Normal Time Mode, push the Reset button. The P or A beside the Alarm Time indicates PM or AM time. The P or A below the Alarm Time indicates a 12 hour clock; an H indicates a 24 hour clock.
TO STOP/START THE ALARM AND HOURLY CHIMES
In Normal Time Mode, hold the Start/Stop button down and push the Reset button (the Date and Day of Week will be displayed) to turn the preset Alarm and Hourly Chimes on, or off (to save the battery). To test the alarm, hold the Reset button down. The alarm and chimes are off when the alarm and chimes icons are not displayed.
TO STOP THE HOURLY CHIME
In Normal Time Mode, hold down the Reset button (the Alarm Time will be displayed) and push the Mode button until the Day of Week display is no longer highlighted; otherwise the hourly chime drains the battery.
TO SET THE TIME
To Fast/Forward until the correct number is displayed, hold the Start/Stop button down.
To set the Month of the Year, select the Time Reset Mode and push the Reset button until the Month of the Year number flashes; push the Start/Stop button until the correct Month of the Year is displayed and push the Reset Button.
To set the Day of Month, select the Time Reset Mode and push the Reset button until the Day of Month number flashes; push the Start/Stop button until the correct Day of Month is displayed and push the Reset Button.
To set the Day of Week, select the Time Reset Mode and push the Reset button until the Day of Week display flashes; push the Start/Stop button to until the correct Day of Week is displayed and push the Reset Button.
To set the Hour, select the Time Reset Mode and push the Reset button until the Hour number flashes; push the Start/Stop button until the correct Hour is displayed and push the Reset Button. For a 24 hour clock, push the reset button until an H is displayed. For a 12 hour clock, push the reset button until an A or P is displayed.
To set the Second, select the Time Reset Mode and push the Reset button until the Second number flashes. The Second number resets to Zero everytime the Start/Stop button is pushed. If the Start/Stop button is pushed as soon as the Second hand on your computer and watch are the same, the watch will be accurate to one second (to set your computer time to the second, log on to the Internet, right click on your PC's time display, select ADJUST DATE/TIME, INTERNET TIME, UPDATE NOW). The setting of the Second number will not be affected by setting the Minute number afterwards.
After the Second number is set, set the Minute number by selecting the Time Reset Mode and pushing the Reset button until the Minute number flashes; push the Start/Stop button until the correct Minute is displayed and push the Reset Button.
TO SET THE ALARM TIME AND TURN ON THE ALARM
Choose the Alarm Reset Mode. The alarm is turned on everytime the Alarm time is reset.
To select the Hour, push the Start/Stop button while the Hour is flashing and until the correct Hour is displayed, then push the Reset button (the Alarm and Hourly Chime icons will appear).
To select the Minute, push the Start/Stop button while the Minute is flashing and until the correct Minute is displayed, then push the Reset button.
Push the Mode button after the correct Alarm Time has been selected. The Alarm and Hourly Chime icons will be displayed beside the Second numbers.
The P icon indicates PM. The A icon indicates AM. The H icon indicates a 24 hour clock.
TO USE THE STOP WATCH
Choose the Stop Watch Mode. Push the Start/Stop button to begin the lap time. To pause the Stop Watch push the Start/Stop button to stop it and push it again to continue. To reset the Stop Watch to zero, stop the lap time by pushing the Start/Stop button, then push the Reset button (otherwise the Stop Watch will continue counting after other Modes are selected).
Apr 20, 2018 • Watches
How do I set digital watch of UL1159
press MODE button 3 times on left screen DAY will flash press RESET MINUTE will flash, change minute what you want by pressing START.
press again RESET button HOUR will flash press START to change hour.
Press again RESET button DATE will flash change same way.
press again RESET button MONTH will flash change same way.
press again RESET button DAY will flash change same way.
After done press MODE to bring back normal time position.
Changing ALARM ....
press 2 times MODE button. Alarm HOUR will flash press START to set alarm hour.
Press again RESET button Alarm MINUTE will flash press START to change.
After done press MODE to bring back normal position.
SO YOUR TIME & ALARM GET SET. images?q=tbn:and9gctqfaospxemzn5ytb2yvmxsagwhcrw-zhdezmqvoulno244gvhvkgaae8w
The hands on my Citizen watch (movement caliber number C320) don't reset properly. I have followed the factory instruction several times with the same result: the minute hand moves to a position 5 - 10...
This is normal. The watch begins timing when you reset it. That 5 to 10 minutes is the time that it took you to do the all reset procedure and you can see that the same time is shown in the digital display - so everything is aligned. It is actually pretty cool that it does that. Source: just did the all reset having dropped my watch. Love this watch!
2answers
My husband's watch keeps resetting to 1/1/05 Eastern time. I've reset it a few times and its good for a few days then back to 1/1/05 Eastern. We live in the West and it's 2010 (so he can look at his watch...
Hi,the problem is either from a weak battery or a mechanical fault in the engine of the watch,
i think you should replace the battery,if the problem persists afterwards,then it's time to give him a wrist watch as a birthday gift.
Be cool.
1helpful
How do you reset the time? My grandson was
you can find a mannual exper [url=http://www.wowgoldeur.com/]wow gold[/url]
Dec 25, 2009 • Watches
1helpful
I have a DKNY OLED watch, but when I press the button for the time, it keeps resetting itself (both time and date) and no matter how many times I reset the time, it keeps resetting itself. How can I fix...
It sounds like your watch is not coming out of set mode. Make sure that when you are done setting the watch that the display is no longer flashing. This is usually done by holding down the mode or reset button.
If this is not the case then have the watch AC'd. As long as there is no problem with the circuit board this should fix the problem.
9helpful
2answers
I need to find someplace to download the instructions, since mine didn't come with any
I just bought a Sportline 241 last week. The instructions are as follows. Note that there are no instructions for setting the 12/24 hour time option. Mine is in 24 hour mode (which is what I wanted), but I do not recall if it arrived that way or if I stumbled onto this mode when setting the time/date or alarm functions.
I hope this helps.
SPORTLINE 241 WALKING ADVANTAGE KEYCHAIN STOPWATCH
FEATURES:
24 hour stopwatch
Time-of-day and calendar
Alarm clock
BATTERY:
Replace with LR41 battery
TO SET TIME AND CALENDAR:
From normal time display, press MODE button three times to enter Set Time/Date Mode. Seconds is automatically selected.
Press SPLIT/RESET button to cycle through minutes, hours, day, month, day of week, seconds.
Press START/STOP SET button to change digits on any of the above (seconds only: resets to 00).
Press and hold START/STOP SET button to advance digits rapidly.
Press MODE button once to return to normal time display.
From normal time display, press and hold START/STOP SET button to see the month, day, and day-of-week.
TO SET ALARM:
From normal time display, press MODE button twice to enter Set Alarm Mode. Hours is automatically selected.
Press SPLIT/RESET button to cycle through minutes and hours.
Press START/STOP SET button to change digits.
Press MODE button to return to normal time display.
From normal time display, press and hold SPLIT/RESET button to see the alarm time setting.
TO ARM/DISARM ALARM SOUND:
From normal time display, press and hold SPLIT/RESET button, then repeatedly press START/STOP SET button to arm/disarm alarm sound.
Alarm will sound when indicator shows in upper right corner.
Release SPLIT/RESET button to return to normal time display.
TO ARM/DISARM HOURLY CHIME SOUND:
From normal time display, press and hold SPLIT/RESET button, then repeatedly press MODE button to arm/disarm hourly chime sound.
Chime will sound when dashes appear along top of display.
STOPWATCH OPERATION - GENERAL:
From normal time display, press MODE button once to reach stopwatch timer display.
After use of any stopwatch feature, press MODE button once to return to normal time display.
START-STOP (TIME-IN/TIME-OUT) TIMING:
With stopwatch timer on display, repeatedly press START/STOP SET button to start or stop the timer. When timer is stopped, press SPLIT/RESET button to reset timer to 0.
SPLIT TIMING:
With stopwatch timer on display, start the timer with START/STOP SET button. Repeatedly press SPLIT/RESET button to split or release the timer. Press START/STOP SET button to stop the timer. Press SPLIT/RESET button to reset timer to 0.
1-2 FAST FINISH:
Press SPLIT/RESET button for STOP #1.
Press START/STOP SET button for STOP #2. The stop time for #1 will now be shown.
Press SPLIT/RESET button. The stop time for #2 will now be shown.
Press SPLIT/RESET button to reset the timer to 0.
Apr 17, 2009 • Watches
My timex watch is not right because the time is 24 hour time and i want to know how to change it to normal time
Select Time reset button (right lower side) until seconds flash
Select Start button on face and cycle through until 24-HR
Select Lap/Reset
Apr 13, 2009 • Watches
5helpful
I have an Athletic Works watch and can not turn off the alarm.
the mode button controls the different functions of the watch.  time, alarm time, stopwatch, timeset, alarmset, in a repeating cycle.  Make sure you are on the time function (seconds ticking and changing every second, but not flashing twice per second.  This is the normal mode that shows the time.
 A press of the lap/reset button (labeled) will show the alarm time, Unpress will show the time of day. Press again toshow the alarm time. Press and hold the lap/reset button will show the alarm time again, but it will hold there.  While holding this lap/reset button, press the start/stop button (labeled). This will turn on (or off) the alarm (tiny indicator).  Press this start/stop button repeatedly (while still holding the lap/reset button and you will see the indicator turning on and off with each press.  Stop this button pressing with the indicator OFF, let up on the lap/reset button, and the time will return to the screen.  The alarm will now be OFF.
214helpful
10answers
How do I adjust date of my watch bought from GAP
Here is the manual from GAP customer service.
Dear gap.com Customer,
Thank you for your email regarding the Sporty Printed Watch user
instructions. Please accept our apologies that no directions were
received with your order.
The instructions are as follows:
Button Functions:
A. Light
B. Mode
C. Start
D. Reset
Standard Time Adjustment:
1. To set the time, press the Mode button three times (The seconds and
the word Tuesday should start flashing).
2. If the seconds position shows less than 30 seconds, pressing the
Start button will reset the seconds to 00. If the seconds position shows
more than 30 seconds, pressing the Start button will reset the seconds
to 00 and the minutes will increase by 1.
3. Press the Reset button until the area you want to change starts
flashing (i.e., second, minute, hour, day, month, and weekend. Press
Start button once for per unit increment, press and hold for 3 seconds
for speedy advance.
4. At completion, press Mode button to resume standard time display.
To reset the Alarm:
Press the B: Mode button until you reach the alarm.
Press the D: Restart button.
Press the C: Restart button to get back to the time
Top Casio Watches Experts
k24674
Robert
ZJ Limited
ZJ Limited
Are you a Casio Watch Expert? Answer questions, earn points and help others
