SOURCE: Washer will won't run cold water cycle
Some
washing machines allow cold water to enter only during certain cycles.
Others intermittently allow hot and cold to enter, to temper the
temperature of the water. Consult your owner's manual if you are unsure
about whether the machine is acting abnormally.
If you're sure the machine is not working the way it used to--or should--check the following.
Hope that helps! Should you have any further questions,
please feel free to post them here.
P.S. – I would greatly appreciate a FixYa!
rating if the solution I provided fixed or helped you fix your problem.
Thank you for using FIXYA!
Cheers!
IrishDruid
SOURCE: no cold water Whirlpool top load washer AP595033
Your cold water celenoid has gone out. There is no way to just replace the cold itself, So you have to buy the whole water valve. That will fix ya up!
SOURCE: hot water doesnt work, switch to warm and warm comes out.
If the cold works on cold wash but the hot don't work on hot wash . Then yes the switch is bad.give What model is it?
SOURCE: water temperature control not working
the fill hoses are backwards,,,reverse fill hoses...on the job...also your under warranty ..call for service but you can do it your self..
SOURCE: my whirlpool washer fills up with hot / warm water
The amount of water on the rinse is lower becaus it's using cooler water. You stated that the cold water isn't working.
Shut the water supplies off. Take the hoses loose from the hose bibs. There should be screen washers in the end of the hose. These are to catch the sediment that normally flows through the water supply pipes in our homes... Take the washer screens out and clean them with an old toothbrush.
Reinstall and while you're at it clean the hot side too.
Then take the machine end of the hoses off and check that it's all clear there as well.
Re install and run your machine on a cycle and monitor it to see if there is better flow on the cold wash cycle AND the rinse portions of your cycles...
If there is no screen washers in the hose, chances are you'll need to clean the water supply valves in the machine... real fun.. HOPE There's washers in your machine..
K
