Searching for the lower blade guide for Ryobi BS903 bandsaw. Gift from my daughter in the Army stationed in Germany.
Testimonial: "I just ordered the part and will post a comment. Anyway having a chance of being a solution is better than no solution. Thanks Ron"
SOURCE: Sir, all I need is a manual for a Ryobi band saw
The manual for the Ryobi BS903 can be downloaded from this link:
http://www.ryobitools.com/product_manual/file_url/37/BS903_979_trillingual.pdf
SOURCE: Ryobi Bandsaw model EBW4023L will not cut straight
I do a lot of resawing with mine and I have found that a 3/8" wide blade gives me nice straight cuts.
SOURCE: I need an Instruction Booklet for a Ryobi H.B.S.
I rang Ryobi ...Aukland . God knows how you lot came up on the computer ... I dont need a panel of experts or Registering or an Account with a Panel of Experts , Mr. Fixya , Mrs Fixit et al.
Just cancel everthing . I don't need your assistance . Please NO MORE CONTACT >
SOURCE: i just purchased the ryobi 9 inch bandsaw, used it
Depending on what type of blade you are running, the teeth on the blade have a "set" to them which defines the kerf you leave when sawing. The set is usually one tooth pointing to one side while the next tooth points to the other etc. This is to provide a way for the blade to cut and eject the cut material without binding. Circular, hand, and hacksaws have a similar tooth arrangement.
SOURCE: Ryobi 902 bandsaw makes high pitch noise. have adjusted all guides and thrust bearing
The noise might not be coming from the blade, but perhaps from the bearings on the top or bottom wheel. Unplug it and open the covers. With the blade still on, turn the wheels by hand to see if you still get the noise. Then remove the blade and turn the wheels independently by hand. Then plug it back in and run the motor (with the blade still off!). Of course with the blade still off, the load on the wheel bearings will be very light, so maybe you can provide a bit of load by pressing a wheel or or caster against them as you turn them. Be careful. Good luck!
