SOURCE: Front load Frigidaire Gallery washer
You are having a door switch problem change it out and you will have a new washing machine.
SOURCE: frigidaire front loader - clothes come out very dry
be sure and ckd fill hoses the screen on cold hose may be plugged the first bit of water is usually hot or warm to flush detergent the remainder is warm or cold also cold is normally used on all rinse
SOURCE: Frigidaire washer won't wash
checking brushes can normally be done in situ. you will need a simple multimeter to put across brushes to check continuity but disconnect wires to brushes before doing this. worn brushes would normally cause no motor rotation at all.
replacing brushes can sometimes be done in situ but often it is easier to get the motor out.
SOURCE: I have a frigidaire front load washer, it and the clothes stink.
I have read that using Nu Fresh in a few of your loads will take care of this problem.
SOURCE: My washer will not spin the water out of the
Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
This is usually what is wrong with a top loader, it may help with the front loader, it is the best info I can offer before I go to bed.
This info below won't work exactly for you but may help you to understand what the problem my be.
Normal
0
false
false
false
font-size:10.0pt;
If it doesn't spin or pump, it could be that
your pump is seized or something is stuck in it. The agitator is operated by a
different motor. Turn OFF the power. and remove the front vertical panel by inserting
a drywall knife in a the top right about 4" in from edge at the joint
1" down from the top, push the clip back to release that corner, get
another knife and do the same to the left top corner, the pull the top of the
front panel and swing towards you, then lift off and remove. Discount the
two hoses to the pump, one from the drum the other that goes to the back.
Be ready for a considerable amount of water to come gushing out, use a hose to
direct to a floor drain. Check to see if something is stuck in the pump
or the hoses, remove it. Check to be sure the impeller spins. If
you found something restricting the flow or pump, remove it and re
assemble. If the impeller won't spin easily, then you need a new pump.
I appreciate your post, Kathy Saalfeld!
From my understanding on permanent press your Frigidaire washer will not spin out enough water. This could be a possible issue with your control panel or sensor within the inside of your washer. You may want to review your drain tube to assure that it is not restricted or kinked. This could be a possible problem with your drain pump or timer. You may need to consult with a professional technician for a proper diagnosis and repair to be performed on your washer. Good luck. -Matt
I appreciate your post, Rachel Kovach!
From my understanding your Frigidaire frontload washer is not spinning the final spinning and the clothes are still wet. If you washer is overloaded it will not spin properly to release the water out of the clothes. Also, a small load will cause your washer to not spin properly. You should additionally check the drain hose to make sure it not kinked or twisted that could cause your improper draining. If all that checks properly it could be an issue with your drain pump, motor, and control panel. I would suggest consulting with a technician for proper diagnosis and repair. This will help avoid unnecessary part purchases. -Matt
