SOURCE: Phaser 7300N paper jam
Problem:
The Printer's Front Panel Displays Jam At Top Cover; Open Top Cover To Clear (A7)
Cause:
Solution:
Fixed! Did not fix.
TRY FIRST (Solutions without parts):
1. Unsupported media. - Load supported media and set the media type correctly. 2. Dirty exit rollers. - clean the exit rollers. Paper catching on the duplex guide assembly. - Remove and reinstall the duplex guide assembly. Fuser not fully seated. - Reseat fuser
REPAIR/INSPECT/PREVENT PROCEDURE:
1. Clean feed rollers and exit rollers only when dust or
debris is visible.
2. Clean the LED assemblies.
3. Check version of print engine and image processor
firmware; as appropriate.
4. Check cleanliness of interior and exterior of printer,
including fans; if necessary, clean (dust or vacuum) these
areas.
5. Review proper operation of printer using a customer
file, if possible.
6. Review with customer all work that was performed; also
discuss how to properly care for their printer.
Rev DT: 01 22 2003
SOURCE: Xerox Phaser 7400
That is caused 99 percent of the time by the fuser.
There is a solid aluminum roll and a silicon rubber ( pressure) roller in the fuser. The pressure roller either developes some flat spots from park ( non running) time and over time heat and use cause it to deform and become out of round. What then happens is when the paper enters the fuser it does so with a slight twist, and the pressure of the fuser, for lack of a better term, Irons in that crease during the fusing process.
Gave the explaination so you would understand what is happening.
What code is comming up with the jam? That would help me narrow it down for you.
SOURCE: Xerox Phaser 5500 printer...paper stops halfway thru fuser unit.
Are the paper tray settings correct? If you have the tray mis adjusted, such as the tray thinks it has 14 inch paper in it and it has 11 inch, it will just shut down like that.
Make sure the settings are correct on the computer and the printer.
Also, its unlikely but the latch for the load springs in the fuser may be unlatched, but you shold NOT be able to close the covers like that.
SOURCE: xerox phaser 7400 I'm getting large black streaks
That would be the drum 99% of the time. A fuser is what heats up the paper and the toner so it will stick properly. If it is "smudging" then its the fuser. But is it is lines sometimes with dots in them that is a bad drum.
start a print from tray 1/manual feed and just as the trailing edge of paper is entering the machine; quickly open it to stop print and take out the cartridge and look at it's drum and the paper underneath. If the issue is there at that point then it would point to loose toner residue underneath the cartridge. if not then the fuser area has to be cleaned. Wipe the area clean with a lint free cloth, do not use compressed air.....
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
