Is it possible to change the scan engine in the MC9090 to a long range version - if so what is the required model. We have a number of short range scanners and want to change the scan distance. I have seen a qty of SE-1200-LR-I000A long range scan engines on Ebay and wonder if they would work Thanks Adrian
SOURCE: SYMBOL MC9090 - LASER READER NOT WORKING
You may need to replace the scan engine - I can help you out with this (or any other issues you may be having).
Contact me if you need anything:
Ian
DC Solutions
[email protected]
SOURCE: Symbol MC9090 scanner disabled
You may need to reflash the OS. you can normally download it from symbol webpage. you will need a cradle and an SD card.
SOURCE: Types of Barcode that can be scanned using Symbol MC9090
It can read all standard symbologies apart from PDF symbologies unless it is equipped with an imager scan engine.
SOURCE: Cant activate PCCARD-PHOTON1 in Symbol MC9090
First thing is to run the wireless utility.
Start >> Programs >> Fusion >> WCLAUNCH
Once thats running an icon will apear in the task bar.
Click the icon and select "Enable Radio"
If you need any more help then please do not hesitate to contact us:-
[email protected] or TEL 01202 620955
http://www.biastechnology.com/
SOURCE: how do i update the firmware on a Symbol MC9090?
http://support.symbol.com
go to the link above, type in the vs of the mc9090 that you have, for example, firmware upgrade for mc9090-g
let me know if you need anything else
Kim Ganoe
Datex Corp
800.933.2839
