So, you want the CURRENT population in Michigan? Are you also interested in the VOLTAGE population, or only the current? You do know (I hope), that if you had both the current AND the voltage, you could calculate the WATTAGE population as well!
Thus, the present year population ought to be around 19.8075 Million and the anticipated population of New York of the year 2016 ought to be 19.865 Million. The US Bureau estimates that the population of New Yorkwas 19,746,227 on July 1, 2014, a 1.9% increase since the 2010 United States Census.17 Jan 2016
You must first understand the problem on your own before you can do it on the calculator.
Calculate the difference in populations 240 000 -206 000
Calculate the time difference 2010-2000.
Divide the difference between populations by the difference in years.
Multiply the result by 100 % if you want a percentage value.
My manual for P4P800-VM says :- Mode Dimm A1 DimmA2 DIMM b1 dIMM b2 single ch 1 populated 2 populated 3 populated 4 populated ---------------------------------------- ---------------------------------- Dual ch 1 populated populated 2 populated populated 3 populated popuated populated populated for dual channel 3 configuration you may install identical dimms in all four sockets or identical in A1 and B1 [blue ] and identical in dimm A2 and dimm B2 [black sockets ]. Probably same as yours Good luck 64bvt
