My Fagor dishwasher stopped filling up with water. If I put some water in manually it will start to work.The machine is 15 years old but was hardly used, only once every fortnight. Can you help please?
SOURCE: Miele G851 SC intake/drain light flashing
Hi Dadcar, Your main wash pump has seized (or stuck). Disconnect machine from power & water, Tip machine on its back. Remove screws that hold the bottom tray on. Remove hoses to main motor, remove electrical connections & remove motor (one screw that holds motor is actually on the outside back of the machine(you will see what I mean). Try to rotate (unstick) the motor (this can sometimes be done by spraying a bit of WD40 and trying to rotate the impellor with a pencil (careful not to break any of the fins on the impellor. If you cannot rotate it, then a new motor will be required. Replace back in machine in reverse to removal. Good luck...I hope the motor turns for you. PS Whilst you haven't used the machine very much, this in itself is a problem and can cause motors & pumps to stick, and seals to perrsh. Try to use the machine at least once a month. Kind regards
SOURCE: miele dishwasher
My O/H found a considerable amount of gunge in the inlet pipe; that seems to have solved it! Thanks for your interest.
Enid
SOURCE: G892-SC Miele water intake/drain light blinks
The intake/drain light blinks. How do I fix this problem?
SOURCE: Dishwasher fan fills with water
Well, I just took my hose out (pulled both ends off the connectors) and it was indeed full of junky cruddy muck, so blew it out over a waste bin until it ran clear through. Now I've put the hose back on and will see what happens next wash!
SOURCE: Dishwasher not filling
Make sure you get water to the dishwasher. Check to see if the water shut-off valve (located under the sink) is open. If you get water to the dishwasher, but there is still no water inside during the fill cycle, the problem might be with a faulty water valve (located at the bottom of the dishwasher, behind the kick panel, on either side), in which case replace the water valve.
