Question about Frigidaire FRT21H8 Top Freezer Refrigerator
Does outside temperature affect refridgerator
Does lower outside temperature on bmw e90 affect the pefomece of a car
Extreme cold can affect the electronics that govern engine and transmission operation.
Jan 31, 2016 | BMW Cars & Trucks
Iv got vauxhall zafria model 2004 outside temperature symbol is not coming on dashboard is that a big problem should take it straight to gargage
No outside temperature just shows the temperature outside the car the snowflake symbol will not show up until it is cold enough outside it has 2 stages yellow is an initial warning of cold temperatures when it gets to freezing the symbol will turn red.
The outside temp warning is not connected to anything mechanical only the engine temerature gauge is so dont worry it will not affect the running of the car but is just there as a warning of falling temperatures outside.
Feb 13, 2015 | Vauxhall Cars & Trucks
I have eight atomic clocks,none of them have the outside temperature working,all have new batteries???
If your outside temperature is not showing on your clock, that may mean that the clock and the transmitter have lost their connection. To reconnect them you must first take the batteries out of both of the units for 15 minutes. First put the batteries back into the transmitter, and then the clock. Let them sit side by side inside your home. When both the indoor and outdoor temperatures show on your clock with the same reading, or within two degrees of each other, then you may put your transmitter back outside. Remember to keep the transmitter out of the direct sun in a dry place. Also keep it away from metal, which can affect the readings.
Oct 20, 2014 | SkyScan 86742 Digital Atomic Wall Clock
I have my Emerson FR966T wine coller set for 60 degrees, but my cooler never seems to get the high. It always hovers around 58-59. When I heat my house up (never above 68) my cooler seems to warm up to...
Yes, because the fridge is a heat exchanger. The trade off for cooling the inside is a condenser coil on the outside which is warm. If you raise the temperature on the outside it will affect the inside a little. Having said that, the thermostat should keep the temperature within specifications. If you have it set for 60 and it is 58 or 59, to me it is within spec.The difference in 2 or 3 degrees Fahrenheit is tiny.
Also it should be pointed out this is a $63 cooler from Walmart. If you want a good one for storing thousand dollar bottles of Chateau Margeaux, you need a $600 wine cooler with a solid state digital thermostat and controls that talks to your smartphone when the temperature is one degree off..
Oct 21, 2017 | Refrigerators
Is there an ambient temperature range outside of which the freezer won't work well? Will it go down to zero degrees?
It seem ambient temperature will not affect so much inside temperature since any freezer has good insulation. Normally freezer will go down to below zero degree
Oct 10, 2010 | Frigidaire 5 cu. ft. / 142 liter Chest...
Error light flashing - head cold
The printer senses the outside temperature of the room and will give this error when the room temperature is cold. If the print quality is affected, you may need to relocate the printer to a warmer room!
Jun 30, 2010 | Zebra 105Se Thermal Printer
FREEZER NOT FREEZING CONTENTS
I have a similar problem with danby and have been unable to get help - I now HATE Danby Chest Freezers
Mar 10, 2009 | Danby 5.5 cu. ft. / 156 liter Chest...
Water leaking from underneath the unit
hi thanks for the question is there water inside the fridge or freezer if not then the leak is coming from the drain tray at the back make sure the drain hose is located in the tray not outside the drain tray thanks the appliance doc
Sep 27, 2008 | Freezers
Frigidaire FRT21H8 Top Freezer Refrigerator Logo
70 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Thomas F. Schneider
jasbo
jasbo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
