3 year old LG washer WM2277hwWill not start, no LED message or anything. Machine was powered, but just "blinked" and shut off all together. Checked power supply, power is being supplied. Pulled plug and let set. Tried again. No power or any power to display (no lights come on). Removed top panel and checked power to control panel circuit (front of machine). Found some signals going thru cables to circuit board.I'm assuming it is a main panel circuit or the circuit/panel board in front. What would I need to test to see if the main panel/circuit board is faulty? I had assumed that the front circuit board was faulty because I was not even getting light/LED coming on.
Update:
1) have replaced both display and main circuit boards
2) still no LED on main board
I HAVE A BEKO 42WLH530HID TV, AND WHEN I TURN IT ON THE STANDBY LIGHT COMES ON BUT NO PICTURE OR SOUND, I KNOW ITS 1, OFF 3 CIRCUT BOARDS BUT DON,T KNOW WHICH ONE, CAN ANYONE HELP ?
Make sure there's power getting to the washer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power. Sometimes the power cord disconnects at the washer, if this is the case, the wiring must be repaired or replaced.
