I go to turn my TV on whether manually or remote, the green light comes on, I get like a buzzing noise, it does this 3 times in a row and then nothing.
SOURCE: RCA won't come in
This was happening to us also~We found a solution with help from this site. We replace the CP150 capacitor which was bad. We replaced it with a 25v (it is normaly only a 16v 2200 uf). It helped but was not the whole problem. We also had a cold soder joint on a capacitor in the main power supply (the board with the two large capacitors and two transformers, they are tucked far back). This is the borad where the ac cord is connected. Hope this helps.
GOOD LUCK!!!
SOURCE: model d52w19 rca projection tv,will not turn
Thats the eroor for the flyback and CP150 needing replacement you can get the flyback # 259296 and the CP150 at the following link and they give free step by step instructions on how to do the repair.
http://servicemanuals.vstore.ca/
SOURCE: RCA D61W20B
replace the flyback # 259296 and CP150 that should solve the issue. You can get replacement flyback and CP150 at the following link and they provide free instructions
SOURCE: tv wont turn on, RCA D56w20, 56" rear prjection
replace the flyback 259296 and the CP150 capacitor. You can get the replacement parts with free instructions at the following link.
SOURCE: RCA 52inch HDTV (2004 model) green power light flashes 3 times
Replace the flyback 259296 and the cp150 You can get the aprts with detailed instruction on how to do the repair at the following link.
