SOURCE: printing from iphoto - photos are not 4x6 and not borderless
wat pc do u have? are u using mac? if ur using microsoft try these:
go to ur printer and faxes - right click on ur hp printer icon - select preferences - select printer shortcut tab - select the appropriate size - the click ok. that should solve ur problem
SOURCE: Printer (hp photosmart d360) does
Hi.
It looks like the settings have been instable. I suggest you to reinstall the printer and the software provided along with..
Regards
Faraz
SOURCE: With HP Photosmart D7260 Printer, I get
Perhaps you are loading too much paper into the tray. Please try to work through the steps in this troubleshooter and see if it has any effect. If not, please report back with the results and someone will be happy to assist you.
HP OOPaper
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread. If I've managed to answer your question or solve a problem, please take a moment to kindly rate this post....thanks!
SOURCE: Photosmart D7260 does not sense Paper in maintray
I had the same problem. I hadn't used the printer in a long time and it took a few minutes to figure out what I did. This may not be your problem, but there are two sliders on the main tray. The first goes left to right and the second goes front to back. If you've use normal 4x6 paper you put the paper in and push the slider forward to lock in the paper so it prints straight. The problem is if you run out of paper and haven't used the printer in a long time, you may try to slide the paper in just like you would a normal printer. But for it to work, you have to pull the front-to-back slider back, and make sure the paper is forward of that slider. If you've pushed it way forward after trying to shove your paper in, you may have to find something to pull it back out again, because your fingers might not be able to get in that far.
