LIGHT ENGINE SHIFTED TO THE LEFT AND LIGHT IS SHOWING UP ON SCREEN, CAN I MOVE IT BACK TO CENTER?
SOURCE: Do You Have Any Lenticular Screens Left For 50" Toshiba tz50v51
I found a lenticular screen from Sears Parts Direct.. The were in stock as of 8/29/08
SOURCE: picture off center on Toshiba 46" rear projection HDTV
On some models there is a picture position setting. One for horizontal and one for vertical. Don't mess with convergence, that probably won't help. Older models use knobs; new ones use the menu. Either way, you are looking for position adjustment.
Older sets, for each there should be size, hold, and position. Same for menus but it may have a picture that looks like one square offset on top of another.
Good luck. and if you need more help, please state the model #
Ken
SOURCE: Convergence problem with Toshiba TV 42H83
Your TV most likely has a Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
Solution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together convergence repair kits for most models.
The kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, etc. Everything you will need to do the repair yourself.
SOURCE: I have Toshiba 51H84 rear projection HDTV. There
Open the tv up,but don't touch the lamp use a fan open it high setting blow out everythings should clean it.If not lamp might have scatch some how?
SOURCE: broken outer screen on my toshiba progection
Manufacturer Toshiba Part Number 23311898 Description SCREEN FRESNEL 42H Manufacturer Toshiba Part Number 23311897 Description SCREEN LENT 42H81 Manufacturer Toshiba Part Number 23311863 Description SCREEN PROTECTOR
