SOURCE: microSD SanDisk 2GB memory into Panasonic DMC-FZ7
Hey filmoman2008,
If you are really trying to use a micro SD card this camera actually takes normal SD memory cards not micro SD cards.
Sincerely,
Allan
Go Ahead. Use Us.
SOURCE: DMC-FZ7 problems
Have you tried switching the mode dial to a flower icon?
The mode with the flower icon is the macro mode, you can shoot up to 5 cm from the subject.
Also, if you are very close to the subject, then the auto-focus may not function properly if the targeting area is not centered on the subject.
When I shoot macro with my FZ7K, I use manual focus, the auto-focus generally has trouble focusing up close.
I would suggest trying manual focus.
SOURCE: My Panasonic Lumix DMC-FZ7 will not read memory
It wants you to format the card in the camera. This will erase the card so download any pictures on it first using a card reader if necessart.
SOURCE: Problem downloading photos to computer.(DMC-FZ7)
Buy an inexpensive card reader to download your pictures to a folder you create on your desktop.
SOURCE: None of my SD cards (I have 4) will work with my panasonic lumix
This camera uses the SD standard - not SD HC.
Be sure you are using a compatible card!
The highest capacity mentioned in the manual is 1GB althought the SD stanard supports up to 4GB.
