I would recommend that you first check the Hall effect sensor which determines the speed. I had this exact problem (but mine occurred with a 600 professional model) and I actually went out and bought another Hall sensor for about $13. I replaced the original sensor and made sure that the connection between the sensor and control board was nice and snug. My blender worked as good as new! But I was curious to know if my original sensor was defective so I put it back in mixer and again made sure all of the connections were tight. Guess what? My original sensor also made my mixer work! There was nothing wrong with my original Hall effect sensor except the connection between the control board and sensor was not adequate--unfortunately I didn't check the connections before I decided to buy another one. My guess is that the connection between the control board and the sensor probably loosens or comes undone over time from use and vibrations.
1. Download the mixer parts and diagrams from the Kitchenaid website to see what the Hall effect sensor looks like. 2. You'll need a phillips head screwdriver to open up the mixer. 3. Make sure that the connection between the control board and sensor is absolutely tight and snug. 4. Also, make sure that the orientation of the sensor connection between the control board and sensor is correct. it's hard to know which way the sensor should be connected because the control board has three prongs and the sensor can attach facing up or facing down. If, after you've made the connections, the mixer still doesn't work. Disconnect the sensor and reconnect it with the prongs facing the opposite direction and try it. I actually found the right orientation through trial and error. By going through this trial and error, I also had my Eureka moment when I realized that the original sensor probably would also work it were reconnected with correct orientation. 5. This whole process probably takes less than 10-15 minutes to perform.
SOURCE: Kitchenaid K5A mixer 10 speed only runs on fast, no slow speed
Pull the back off and there will be two screws at the top of the Speed Control Plate and a 3rd screw at the bottom. Tighten the top two screws down. [email protected]. Let me know if it works.
SOURCE: KitchenAid wobbles when mixing
The "wobbling" sounds like an issue of beater to bowl adjustment, which can come out of alignment naturally over time and with use of the machine.
If the flat beater is striking the bottom of your bowl, this may cause the locking mechanism to loosen and may cause the mixing head to "bounce" during use.
Your Use and Care Guide will cover the "beater to bowl adjustment," which you can do at home in a few minutes with a flathead screwdriver.
Also, leaking of oil in a stand mixer is not necessarily indicative of a large problem.
Kitchenaid stand mixers are overpacked with oil to last the lifetime of the motor. If the motor sits idle for some time (is not used), the oil may begin to drip from the gears and settle. Oil leakage may primarily be seen from around the beater shaft or planetary action.
A stand mixer can lose up to a 1/4 cup of oil before it needs to be serviced.
It is recommended to run the mixer on speed 10 for 2 minutes in order to redistribute oil back into the motor. In order to prevent future occurences, this is recommended to be done every 3 weeks if mixer is not being used.
SOURCE: my 6 quart kitchenaid mixer paddle is rubbing the ...
Find the screw in the picture as shown and screw it counter-clock-wise which will drop the bowl level down when it is in the raised position and the mixer paddle will not rub on the bowl.
http://www.fixya.com/uploads/images/07F1BE1.jpg
