Question about Asko WL6511W Front Load Washer
Asko WL6511XXL door locked and making clicking sound?
Cannot open the door, and there is a non stop faint clicking noise in the background. There is no water in the unit, I opened the door on the front and drained and inspected the cleanout and it was clean. Powered it on and off several times too, pressed and held buttons, all to no avail. Any idea where to go from here?
6ya staff
SOURCE:
Ian Greenland
  • 351 Answers
SOURCE: Asko W6021 Front Loader Washer Problem
the carbon brushs in the motor need replacing,on the w6021 the fault you get is a clicking sound when you press the start button.
Posted on Mar 02, 2008
Ian Greenland
  • 351 Answers
SOURCE: asko w6021 still not working
check that all the plugs are in the correct position on the board,you may have introduced the fault,because the only fault you had to start with was worn carbons.did you break off any links maybe J4 etc if the original board had the link taken off and you dont do it on the new board you will hard program the new board and will have to order another board. is the machine heating.put on wool wash and select heating you should hear it start to heat.let me know.thanks Ian
Posted on Apr 01, 2008
Anonymous
  • 638 Answers
SOURCE: asko 6221 washer won't drain, now won't fill either
u will hve to get ur control card repaired.the problems u shared with us arises due to faulty circuit control card.
feel free 4 further assistance .rate the particular experts solution as fixya that helps u understand n solve ur problem...
Posted on Jun 20, 2008
Anonymous
SOURCE: can't open door of front load Asko washer 12225
Open the little door on the lower left corner of the front of the machine, and pull on the red tab in there. door will pop.
Posted on Nov 21, 2008
Krazytech
Franklin Ouchida
  • 725 Answers
SOURCE: I have an asko wm200 washing machine. I have an F3
open the little door at the bottom or remove the toe panel... then there is a coin trap... that will let you remove the water there is a black hose with a plug on the end remove plug and drain the water...by turning it and pulling it you can remove the coin trap and you my be able to remove somthing stuck in it... also there is a red string you can pull it and release the door
Hope it helps if NOT let me know more about your problem... and I will help
Posted on Sep 26, 2009
Garage door opener lite flashs and unit makes clicking noise
If this is happening during the close cycle it is because something is in the ways of the door sensors and preventing the door from closing. When this happens the light flashes and you hear this background clicking till you resolve the issue. Or check the wires to sensors - if disconnected ,same thing happens.
May 03, 2017 | Building Materials
Asko 5152 dishwasher door "clunks" when opening and closing. What is that?
Probably nothing serious, but something is slipinga or catching on the door hindge.
Dec 11, 2014 | Asko Dishwashers
Continuous knocking noise from ice maker. Ice maker has been off for past 3 months. Only thing that will make it stop is turning it off or unplugging it.
Hi Marcel,
Thank you for contacting fixya.
Our ice maker recently had its water inlet freeze up, preventing water from filling the trays. The mechanism kept dutifully trying to push nonexistent ice cubes into a bin that never filled up, which might account for the knocking noise in your case.
To defrost it we just unplugged the unit, took all the food out of the freezer section, and left the door open for a couple of hours. It wasn't long enough for any of the frozen food to defrost, and since we were careful to minimize opening the refrigerator section's door, the food in that part stayed cold enough to be safe as well.
Feb 09, 2014 | Frigidaire FPHB2899LF
My Frigidaire electric range/oven started making mechanical clicking or ticking sounds all of a sudden and a "locked" light keeps flashing weakly and the going out. When I open the oven door the...
Hi mike_glenn,
Ok, do the following:
1) Press and hold the "Clear/Off" button on the oven until you hear a beep and the word "OFF" disappears from the display. The word "Lock" will remain in the display until the door lock is disengaged, which could take up to 10 to 15 seconds.
-or-
2) Find the main circuit breaker for your oven. Turn it off for fifteen minutes, then flip it back on. This should allow the door latch to open.
I hope this helps
Kind Regards
JEDEMEYER1
* If this solution helped you, please accept it
Sep 03, 2011 | Frigidaire Kitchen Ranges
No water is going into dishwasher duting cycles. there is water going to the unit though
open the door, in the dishwasher, left front corner there is a white dome. Light grey if ss tub. Remove the dome, 1/4 drive screw holds it down. under that is a float. Make sure it's moving freely. if you lift it you should here a faint click. thats the flood switch. try the water again to see if it fills.
Mar 25, 2011 | GE GLD4450NCS Dishwasher
We have a 25.4 cubic Whirlpool side-by-side fridge/freezer stainless steel look. Since the last 2 weeks....the display lights showing temperatures in fridge and freezer the front water/ice dispenser unit...
the clicking is from the lamp relay which makes the lights flicker and its located on the units rear area in the back,without a model number i cant tell what this boards model number is but you need to replace this whole board as they are non repairable(this is usually caused by a power surge or outage,which can destroy these boards,also even if a lamp in the unit burns out this can destroy this board too)
Mar 23, 2011 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
I have Asko D3350 dishwasher and the Detergent dispenser does not open. We were told to remove the whole dispenser and soak it in water but how do i remove it?
to remove the dispenser is not a 30 second job. You have to remove the door front with a T20 (torx) screwdriver (don't forget the 2 screws in the middle of the door at the bottom) Then you can get to the screws that hold the dispenser in place. Make sure you remove the solenoid from the dispenser BEFORE soaking in water. A more likely issue is either the solenoid on the dispenser has failed and will show signs of burning and/or damage or one of the transistors on the control board may have blown.
Oct 25, 2010 | Asko 24 in. D3350 Dishwasher
I have an ASKO D3250 and it has recently started making a loud noise from the pump area. It starts as soon as the cycle begins and doesn't stop even if you open the door. It seems to stop about 90 seconds...
All power and sounds should stop when any dishwasher door is opened.
Your door switch may be stuck causing it to continue.
The 90 second sound at the beginning of the cycle is the water pump extracting any residual water before taking on clean water for the wash cycle.
Any excessive noise from the drain pump could be debris in the pump. e.g. broken glass.
You can remove the pump and check it for blockage or any foreign object.
Aug 14, 2010 | Asko 24 in. D3250 Built-in Dishwasher
Asko WL6511W Front Load Washer Logo
123 people viewed this question
Top Asko Washing Machines Experts
Gerry Harvey
Gerry Harvey
Joseph Hoffmann
ROB
Are you an Asko Washing Machine Expert? Answer questions, earn points and help others
