Check your warranty. Call for support.
*** The following is for information only.***
* If your player and TV set was working prior to this then it's probably playing a black and white movie or the TV color setting is off and needs to be reset.
* For TV go to menu, Picture, Color set up. (Best to restore to factory settings as a starting point.)
* For DVD try a known "color' movie (at least something later than 1965) if it plays in color then the older disk is B&W.
* If someone pulled out the cable (Yellow, Red, and White) this is the Video (Yellow) and Audio Left-White, Audio Right-Red.
* Check this cord for damage and reconnect into corisponding color coded jacks. Note; this cord will not affect the "color of the set other than not show up at all - Blank screen if wrong plug inserted.
* Call TV support line (or DVD support) for advice.
Aloha, ukeboy57
In order to connect an AV receiver to a TV using component cables (Red & White) you will need to connect the component cables to an available AUDIO "OUTPUT" on the TV (red to red and white to white). Then the other end of this same cable will be connected to an available AUDIO "INPUT" on the AV receiver. The TV (via the menu or setup button) may have to be set to where the audio signal is output to a home theater and not to the TV speakers. Once connected, the AV receiver should then be set to the Audio input used in order to listen to what the TV is showing on screen.
i have white screen on this tv no matter which input it could be on cable /tv or hdmi, dvd,etc tv stays on white screen but audio is good.. how do i fix this??? the tv dont show channels changes or setup when using control just a blank white screen.
Make sure the video/audio cable is plugged in correctly. Red cable into red socket, yellow into yellow and white into white. It is easy to put these cables in the wrong socket by accident and will cause no image to appear on your screen.
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Ur Tuner board,that the tv signal came into that board.U have a little manchanical skill.Take ur tv aparts.Replaced that Tuner board ur tv will work again.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish Tuner board to replacement.
try this
Audio Out of your Cable box colored RED and WHITE is connected to your TV's Audio In RED and WHITE. And connect the VIDEO out of your cable box YELLOW to your TV's VIDEO IN
function c_getProfessional_AskGet_refreshPicture() {
var imm = $("getProfessional_ask_fromprchat");
var val = false;
if(imm)
val = $("getProfessional_ask_fromprchat").checked;
var pOn = $("c_AskGet_checkBoxOn");
var pOff = $("c_AskGet_checkBoxOff");
if(!pOn || !pOff) return;
if (val) {
pOn.style.display = "";
pOff.style.display = "none";
} else {
pOff.style.display = "";
pOn.style.display = "none";
function c_getProfessional_AskGet_toggleImmediate() {
var oImmediate = $("getProfessional_ask_fromprchat");
if(!oImmediate) return;
var val = oImmediate.checked;
oImmediate.checked = !val;
c_getProfessional_AskGet_refreshPicture();
try to trouble shoot if the wire is the problem, how? remove the 3 colored wires from the tv and ps2 then try to use the red color instead of yellow to the video from tv and ps2 (both red) temporarily do not use the yellow color. once a picture appears use now the white for the audio (both white) for left audio once there is a sound you may try the yellow for the right audio. i hope this will help you and hear a positve reply from you.
