Kyocera Mita KM-5035 Printer Logo
W
Wanda Jackso Posted on May 01, 2014
Kyocera Mita 5035
Why are there streaks on page when I copy. Is it the drum?
dijim33
Level 1:
  • Contributor 36 Answers
  • Posted on May 01, 2014
dijim33
Contributor
Level 1:
Answers
36
Questions
Helped
6787
Points
91
Go through the maintenance procedures in your manual. All cleaning should be done which probably includes roller cleaning but you should run it through all the procedures.
Kyocera 5035 scanner c7400
Image formation unit.
Has the drum been removed from this machine.Its either missing or requires replacing
Kyocera mita km 5035 image cycle problem
Ensure that the filters are not blocked and that the machine has sufficient air flow around the machine.
2helpful
Kyocera mita 5035 eror code c6000
i have kyocera mita this machine toch screen is working but numbers manual is not working please give me solution immediately
1helpful
Solution of error code 7410 for kyocera mita 5035
When Your Kyocera Mita KM 5035 Indicates Code 7410, It's the problem with your Drum Unit Or Drum. You Can Solve This Problem Either By Changing If You Have Another Drum Or Buy A New Drum Unit.
3helpful
2answers
C7400 error kyocera km 5035
Error C7400 on Kyocera km 5035 is Image formation unit problem or connector
Hope this will help
KM 5035 cuts off top of copy image. Text is moved higher on page on copy vs original which cuts off the top of text on copy. Can't seem to figure out how to make it stop doing that. Happens the same...
Hello. Sometimes this can be caused by the duplexing mode being switched on. check the duplexing settings to rectify. Also if the paper position sensor is damaged this error can occur. this required a technician to replace.
I hope this helps Regards GM
3helpful
2answers
Kyocera Mita 2050 there are streaks of toner appearing on the pages printed.
If you send a print job or print a report from the copier and there is no streaks then the problem is most likely the thin **** glass to the left of the large glass. It just needs to be claened.
If the streaks are happening when printing and copying then the problem is most likely your drum unit (MK-410) or possibly the fixing unit (FU-410), the fixing unit is the one that gets hot.
As the drum gets old it can cause print/copy issues and the cleaning blade that cleans the drum gets to the point it doesn't clean the drum properly causing streaks.
The heat roller has a teflon coating on it and as the roller gets older the teflon starts to come off and can effect prints/copies.
The drum unit should be replaced every 150,000 pages and the fixing unit every 300,000 pages on the KM-2050.
I hope this is helpful,
Shawn
1helpful
2answers
4helpful
2answers
We have a Kyocera 5035 Copier and getting a message "Page tray is out of order"?? Any ideas on what to do?
if you go into copy mode punch in 1087 1087
press the green start button
punch in 906
press the green button
select the option on the touch screen
and wait until the machine reboots
this should fix any minor problems
Top Kyocera Mita Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Bill Eager
Norman Weimar
Norman Weimar
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
