Question about Haier 7 cu. ft. / 198 liter Chest Freezer HCM070LA
When cleaning my Haier 7 cu. ft. / 198 liter Chest Freezer HCM070LA we tipped to get water out and now it seems to not want to freeze but stays cold
  • 884 Answers
Oil in the evaporator. It may come back if you leave it running for a few days, but usually needs flushing out.
Posted on May 03, 2014
4 Suggested Answers
6ya staff
SOURCE:
Tom Chichester
  • 55370 Answers
SOURCE: Haier 5.3 Cu ft Chest freezer. power is on but compressor doesn't run. There is click sound but nothing happens after.
The click sound is the compressor starter relay closing but if nothing further happens it is likely that there has been a compressor failure
Posted on Apr 11, 2013
walterkunesk
Wally Bald Guy
  • 683 Answers
SOURCE: How much amps, volts and
all this is on label on equipment.
Posted on Feb 28, 2011
Anonymous
  • 124 Answers
SOURCE: freezer freezes but does ever stop running
thermostat is stuck on! set to medium setting and gently tap stat. does it turn off? it was stuck. does it still run? its still stuck. if you feel comfortable find stat and power in and out. disconnect - it has to turn off then. but 99 % of the time its the stat. they fail closed and run 24 -7 or fail open and temps get real hot and they never close and restart compressor . yours appears to have failed closed. sometimes you can firmly twist em max cold to min cold a few times and break the stuck contacts and they'll do ok for a while. try to reset at a little higher or warmer temp when done so its not making and breaking on the same old worn spot again. good luck.
Posted on Nov 21, 2008
Why My haier model hcm070la Chest freezer the compressor is not kick on
check thermostat, or relay on one side or back cclose to the compressor area there is a removable lid. removed and look for a thermostat disconect the 2 wires and bridge them then plug the the freezer on if runs replace the temp thermostat for a new one should be freezer thermostat
Nov 07, 2016 | Haier 7 cu. ft. / 198 liter Chest Freezer...
Magic Chef HMCF7WI is the green light suppose to go off ?
I not 100% sure but believe this is the power light so it should remain on when the freezer calls for cooling and go off when satisfied. If the chest wont stay cold then it sounds like the stat is gone. If it is digital, there may be a power card issue but most chest freezers are run on a standard thermostat with the capillary running up into the base of the unit.
May 17, 2014 | Magic Chef 7 cu. ft. / 198 liter Chest...
Magic Chef #HMCF7W1 should the green light go off?
same as last post... I not 100% sure but believe this is the power light so it should remain on when the freezer calls for cooling and go off when satisfied. If the chest wont stay cold then it sounds like the stat is gone. If it is digital, there may be a power card issue but most chest freezers are run on a standard thermostat with the capillary running up into the base of the unit.
After placing my Haier 7 cu. ft. / 198 liter Chest Freezer HCM070LA in a horizontal or tilted position it doesn't want to freeze
If you have run it in a tilted position, the oil has migrated from the compressor to the evaporator. You need a technician to flush the oil back to the compressor. Only run equipment like this on a flat level surface. and always allow to stand a few hours after moving before switching on.
May 01, 2014 | Haier 7 cu. ft. / 198 liter Chest Freezer...
How to put refrigerant into a gvt44AD
Hi, please help me, my freezer Gvt44ad when I conect to the power start to work for 45 seconds then it is off, can you give me some directions to do something for it?
Jul 02, 2012 | Haier 7 cu. ft. / 198 liter Chest Freezer...
The starter is no longer available. I have found a generic starter here: http://www.appliancepartspros.com/part_details.aspx?part_id=4503017 Does this look like it will work? They have different...
I use this on a regular basis and have had no issues. I believe it will work. If I had some numbers from the compressor plus a brand name such as Copeland, Tecumsah, embraco, etc., I may be able to tell you more about the compressor HP.
Jul 17, 2017 | Haier 7 cu. ft. / 198 liter Chest Freezer...
Compressor runs but freezer not getting cold
Have the gas checked. If the thermostat pick-up is frozen over that could result in the contents of the freezer not getting cold, but for that there would have to be a build up of ice on the sides of the freezer.
Jan 25, 2011 | Haier 7 cu. ft. / 198 liter Chest Freezer...
My Haier 7cu. ft. deep freezer gets hot on the outer walls. Is that normal? It stays hot all the time.
It 's builded that way so there's not condensation around the door frame and on the walls.
Nov 04, 2009 | Haier 7 cu. ft. / 198 liter Chest Freezer...
Why does it get hot on the front and the sides it never did that before
If the food is at normal temperature, then what you are describing is normal.
On a chest freezer the condenser coils are embedded in the outer walls, as the evaporator coils are embedded in the inner walls to provide cooling.
This is the very basic principle of refrigeration. One set of coils (the condenser) are allowed to get hot, so the other set of coils
(the evaporator) can get cold.
When the unit is not running, which is most of the time, the walls will cool to room temperature.
Nov 03, 2009 | Haier 7 cu. ft. / 198 liter Chest Freezer...
Runs fine then for weeks then trips on high limit
Hi, sometimes high-limit goes bad, but why, check to make sure you're not overloaded with produce, check to make sure freezer has good ventilation, if your days are hot, high limit will switch off, to pretect compressor, could be compressor getting faulty, you should empty freezer, clean and restart empty for an hour, if freezing o/k, put back produce, if when clean and empty, does same thing, maybe your compressor is faulty, called a mechanic, or replace high limit switch. good luck.
Aug 09, 2009 | Haier 7 cu. ft. / 198 liter Chest Freezer...
Haier 7 cu. ft. / 198 liter Chest Freezer HCM070LA Logo
222 people viewed this question
Top Haier Freezers Experts
Marvin
Marvin
Dennis Boxerman
Are you a Haier Freezer Expert? Answer questions, earn points and help others
