Question about Westinghouse LTV32W6HD 32 in. LCD Television
Why does my Westinghouse 32" flatscreenTV shows fuzzy psychedelic colors
When I turn the tv on, the color turns a fuzzy bluish green
    New Friend:
  • 25 Answers
Have you tried resetting the TV's settings to the factory default?
You should be able to do that within the settings menu on the TV.
Posted on May 02, 2014
6ya staff
SOURCE:
Anonymous
SOURCE: westinghouse 32 inch screen goes blank
Westinghouse LTV-32w1
replace capacitor c162 on power supply
power supply was a delta electric dps210ep-2c rev01
reheat any solder joints that don't look 100% as well .
such as c310 .
this is a known working fix . try before you buy a supply .
Posted on Apr 15, 2010
dave1645
Dave Naylor
  • 834 Answers
SOURCE: Westinghouse TV no picture just sound. 32
one or 2 caps in the power supply they will be domed from venting
Posted on Sep 16, 2009
dave1645
Dave Naylor
  • 834 Answers
SOURCE: my 32 inch westinghouse lcd tv's screen turned pink when on
your T-con board is failing you need a tech to replace it about a 150 dollar job
Posted on Nov 18, 2009
Bblaster
  • 92 Answers
SOURCE: Negative type images in pink & lime green
I had the same problem....turned out it was the "lvds" cable that runs from the mainboard to the lcd controller board. Simply remove the tape that holds it to the back of the backlight housing and also remove the foil shielding tape from the connector on the lcd controller board.
Posted on Dec 04, 2009
Chi Chu
  • 8457 Answers
SOURCE: Color goes all crazy after tv warms up.
Ur Tuner signal board is dying,must replaced.
Posted on Jan 27, 2010
Testimonial: "thanks for the help."
My samsung hl61a750a1fxza only has blue and green picture only, why?
Your red tube is dead. There are three primary color tubes that create all the colors. A new tube can cost $250 plus installation and then you will have an old, obsolete TV with one new tube. A new 46 inch TV is less than $400 these days.
May 06, 2012 | Televison & Video
All DVD movies are bluish. How to adjust color to be natural?
if you are using component cables, check the cables for correct color configuration to your TV and from DVD Player.Example red to red green to green and blue to blue, if they check out,the possible problem might be a defective cable...
Dec 29, 2009 | Sony Audio Players & Recorders
Bluish color right coener
I'm afraid, it is problem of optics unit block (light engine), there are 3 LCDs red-green-blue for color picture formation and blue LCD sounds bad, please call local TV tech for fix.
Thanks.
Oct 21, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Color of images turned bluish green
Picture Tube is very weak and you could have a tv technician put a booster on it or give it a charge with his charger machine. I must warn you that it might repair the picture tube or burn it out.
Oct 01, 2009 | Televison & Video
Emachine monitor lose color.
HI Bernard,
This sounds to me like the video lead is loose. Could you please try the video lead each end and tighten the locking screws if possible.
Regards
Nick
Oct 29, 2008 | E-Machines eMachines Monitor E15T4
Screen Spots
move your streo speakers or any thing w/magnet
Jul 06, 2008 | RCA F32650 32" TV
Video probs
Which cable are you using? Are you using the component cable? Have you accidentally switched the red/green/blue somehow? Or may someone have played a trick on you, rearranging them?
Also check PAL/NTSC settings and capabilities on the 360 and your TV.
Nov 26, 2007 | Microsoft Xbox 360 Console
Blue screen
replace the pcb convergence board,, It costs $96 and takes 10 minutes to replace you will have to manually line up your convergence afterward as the settings go to factory default. Everyone that owns this set has or will have to replace this part within 3 years
http://www.samsungparts.com/search/search.asp
Or Vance baldwin online
Part number bp94-00155a
Aug 12, 2006 | Samsung HCN4226W 42" Rear Projection...
Westinghouse LTV32W6HD 32 in. LCD Television Logo
182 people viewed this question
Top Westinghouse Televison & Video Experts
CoppellTVRepair.com
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
