Question about Samsung Galaxy Tab 2 7.0
What to do if my galaxy wont charge
My galaxy wont charge. When I connect it to the charger it has a big battery on it but wont turn on. I have a lot of things that I need to get to on there
    New Friend:
    Problem Solver:
  • 9 Answers
Try this. hold down start button for full minute.may work
Posted on Jan 12, 2019
    New Friend:
  • 3 Answers
I got mine second-hand so I didn't see the instructions, but these can be particular as to sequence of connections. I go: plug charger into wall, turn power on, turn tablet off (ideally), then plug in charger lead to tablet. Leave to charge to 100%, but not much longer (or it gets a bit unresponsive), then turn off at wall first & unplug everything.
Posted on May 17, 2014
  • Heidi Jan 12, 2019
    Also, if the battery has been flat for a long time, it apparently needs a bit of a pre-boot by removing it, waiting about 20 seconds, replacing, then charging the unit. It might take hours for the battery symbol to move out of the 'flat' image, then it's away charging again. (This happened on my ancient iPad, so I thought I'd throw the possibility in here for other, older devices.)
    Scholar:
  • 178 Answers
At this level of charge their is not enough to start the boot process , if it doesn't charge at all their may be a fault with the Battery cell , however i had a similar issue, just leave it for a while, if their is still no indication that its charging or it wont turn on their could also be a problem with the Start Button
Posted on May 13, 2014
6ya staff
SOURCE:
My tablet wont turn on or charge
Unplug the Battery, hold the Power button for 10 seconds to discharge any capacitors, Plug the battery back in, Charge the tablet until the battery reaches 100% (Factory Charger preferred), Turn it on. If this doesn't work it could be a bad battery, bad charger or bad USB connector.7 Jan 2014
SOLVED: Why won't my tablet charge or turn on? - Samsung Galaxy ...
https://www.ifixit.com/Answers/View/.../Why+won't+my+tablet+charge+or+turn+on https://www.google.co.uk/webhp?sourceid=chrome-instant&ion=1&espv=2&ie=UTF-8#q=My+tablet+wont+turn+on+or+charge
not saying any off this is going to work for you but read it anyway.
the reason i say this is because i had some one else with the same problem but it ended up it was the tablet itself was faulty.
Nov 29, 2016 | Tablets & eReaders
Why wont my Samsung Galaxy tab 3 notcharge past 60%
The battery may be unable to charge to more than the 60% level.
Oct 07, 2016 | Samsung Galaxy Tab on 3 Mobile Tablet PC
Are there battery recharging problems with Galaxy Note 10.1?
Possible both try charging unit using a friends 10.1 charger if same results in battery been partly charged. The answer is yes its the battery
Oct 11, 2014 | Samsung Galaxy Note 10.1"
My Samsung Galaxy 3 Tablet wont charge
Have you tried a different charging cable?
Did you allow the battery to run down until it was completely drained?
- If so then try the following;
Watch this video (link below). You should only remove the back cover, disconnect and reconnect battery cable. Disregard the rest of the video as I could not find one doing ONLY what you would need to do. Follow the instructions to remove the back of the tablet then disconnect the battery cable(careful not to damage the circuit board), reconnect the battery cable, and replace the back cover. Connect the charger, within a minute the screen on the tablet will pulse/flicker which is good news, allow it to charge a while, turn on the device, turn off the wireless wifi, click the power button to turn the screen dark again, and allow to charge for another 6 hours or till fully charged (when not connected to wifi the background processes will affect the charge time, on a weak charger it may not even charge like from an usb port on a computer).
Again, you should only be concerned with the video up to about the 1 minute and 15 second mark. You only need to disconnect the cable then reattach it. ONLY DO SO if you are comfortable doing so. If you have never worked on electronics before or are uncomfortable find someone to do it for you.
Galaxy Tab 3 Battery Replacement and Screen Repair Disassemble and fix
Aug 01, 2014 | Samsung Galaxy Tab on 3 Mobile Tablet PC
Why wont my Samsung Galaxy Tab on 3 Mobile Tablet PC charge
either your battery is shot as in dead or your charger is faulty
you could try to charge it using a usb lead in your computer or another usb port to see if that works , or try another charger to eliminate your lead /charger you are using
A samsung galaxy player 3.6 that wont turn on
The charger has a function that restores the battery operation parameters by discharging then charging the battery a number of times. Refer to charging instructions in the pack but I think the cycle is a 3 hourly one, time to charge from a full discharge. If the charger thinks the battery is dead then it will try to recover the battery using this process. You may have left the charger on long enough to charge then also discharge the battery.
Start again and charge for the time in the instructions ONLY, if you are not sure of the time try it for an hour, then without disconnecting the charger turn the unit on and take particular note of any screen messages, if any.
You should be able to continue as normal now, but still be aware of the time you are leaving the charger connected for, as it may take some time before it returns to normal operation and stops trying to recover what it thinks is a dead battery.
May 04, 2014 | Samsung Galaxy Tab Tablet PC
Samsung galaxy tablet 10.1 wont charge show a 1/4 yellow battery then turns off show battery again then shuts off
Either the battery or the charger is done for. If you have family or a friend with the same unit, you can verify your charger and your unit with their equipment.
Good Luck.
Mar 11, 2014 | Samsung Galaxy Tab 2
My Galaxy tab 7.7 wont charge, I tried to charge it yesterday when the battery was still 50% charged but now it is down to 15% and my tab won't charged. I am using the original charger, please help!...
my mama said that mayb ur need a new charger cuz Samsung is sending me a new 1 and I think that\'s y. I hav a 7 inch tab 2 n I love it but it stop charging so I don\'t no whats wrong but im getting a new charger so its all good and guppy now :) ill keep u updayted cuz I think its the chargers falt not the tablets!! idk if not then ill just reset my tab and cry my eyes out cuz that sucks big time I meen really who wanna reset there tablet? not mee! but what the hell..mayb a new charger will help the little baby...
Jan 23, 2013 | Samsung Galaxy Tab 7.7 P6800 3G 16GB...
My Samsung Galaxy Note 10.1 battery not charging can you please tell me why
Same problem on my Samsung Galaxy Note 10.1 (GT-N8013) w/ OS 4.1.2
It just boots up and shuts down.
Dec 06, 2012 | Samsung Metallic Gray Galaxy Note 10.1in...
Samsung Galaxy Tab 2 7.0 Logo
172 people viewed this question
Top Samsung Tablets & eReaders Experts
Eric Rotmil
Eric Rotmil
Jerry Greenberg
Jerry Greenberg
Are you a Samsung Tablet and eReader Expert? Answer questions, earn points and help others
