I changed Anew toner but it comes agin please help me?
If its not adding toner there could be 4 possible causes, 1.make sure all the covers are closed, if they are not then the machine will not "run" to add toner. 2.Did you check to make sure there is enough toner in the toner bottle. 3. when the machine starts running/adding toner, can you feel a vibration or hear noise like gears grinding/slipping, if so, call a technician to replace drum/dev gears.4. when you open the toner tray/harper/hopper, at the bottom there is a flat silver sliding plate, when you slide it open, is there toner falling oout of that hole, if not, ask a technician to strip and clean the toner tray/ harper/ hopper.
SOURCE: RICOH AFICIO MP 2000
you must clean developer and drum section. after that you must put new developer and initialize it. After that place in correct toner.
SOURCE: adding developer to the new ricoh aficio mp 1500
Are you a tech? I suspect not. You need to remove the drum unit, disassemble, separate the drum from the development unit. Remove cover of developer unit, add developer, reassemble, and run SP2214 to calibrate.
This is NOT a procedure to be performed by an end user...no disrespect intended.
SOURCE: Ricoh Aficio MP 1600 Le error code sc 322 occured
Try to reset the machine by turn it off and after 5 second turn it on again by the red switch-plug which is located on the left side in the middle.
If this do not help you will need to cal a technician because the machine have problem with the laser unit.
Please answer do this is helpful.
Regards
SOURCE: Ricoh Aficio MP 1600 Le Bypass setting
Select bypass tray an press the pound key # .
This will get you tu where you can select the paper type and size.
