The WorkDay Function returns a number that's the serial date that is the indicated number of working days from a given date (the starting date). Working days EXCLUDE weekends and any dates identified as holidays. Use WORKDAY to exclude weekends or holidays when you calculate invoice due dates, expected delivery times, or the number of days of work performed.
The Syntax is:
=WORKDAY(start_date,days,holidays)
where:
- start_date is in Date format (and can be a calculated value);
- days is a number of elapsed days after start_date (can be calculated, can be negative to indicate a date BEFORE start_date);
- holidays is an array of holidays you can specify if desired.
SOURCE: Excel Formula
Yes you can and there are two choices. The simple solution is to label a cell "divide by" and put your number in that filed. Then, by changing only that, your answer (in a separate cell) will be available.
There are more complex solutions -assuming your divide by number had some rhyme and reason that could be put in place but.....try this first and at a later date go back and play. Learning to do that will give you more than a fair amount of Excel expertise....something you may find fairly valuable as you continue on using Excel. FYI...I have developed full blown applications on Excel....it is an excellent tool. Hope this helps....Tango.
SOURCE: CAN'T CALCULATE DATES TO GIVE DEADLINE
cell 1 (date format) = start date
cell 2 (number format) = number of days = cell 3 - cell 1
cell 3 (date format) = deadline = cell 1 + cell 2
SOURCE: i want the all excel formulas
You will never find a fully comprehensive list anywhere because there are literally hundreds in the basic Excel application and thousands that can be added in as you go via macros. More are being added every time a new version of Office comes out.
But, the easiest way however to get a basic list of functions if your not printing is to hit the function button and simply scroll down the list. The syntax (an example of the method by which you should be formatting the formula) and a definition will list in the bottom of the dialog as you select each function.
That said, you are better solving individual problems as you learn Excel then trying to memorize all the functions themselves. Many, such as mathematical operations are common sense anyway.
SOURCE: When using the excel MID function, the result is
1/ Did you check that the formula begins with =
2/ Are all the parenthis in the correct place.
3/ Start by using the MID function by itself until you get it right.
Formulas are used to specify calculations based on values in designated cells. Excel supports basic calculations as well as statistical, trigonometric and other specialized functions.
Formulas used in Excel must follow a certain syntax.
