Bowl lift will not work
Use this link to find parts. Have your model number available.
http://shared.whirlpoolcorp.com/product_literature/search.jsp?siteCd=KAD
Once you have the correct part number, you can google "KitchenAid replacement parts" and purchase from a vendor of your choosing.
SOURCE: KitchenAid Parts
Given the age of a 3-C stand mixer, finding additional parts for it will be exceedingly difficult. The best recommendation is through E-Bay or antiques stores - a specialty dealer. Kitchenaid parts distributors will no longer have anything in inventory for the 3-C mixer.
SOURCE: My Kitchenaid mixer (k5ss lift bowl?) smells hot
I think you have a K45SS. It sounds like there is a problem with one of the gears, probably the worm gear. The worm gear is designed to be the first to fail if the mixer has struggled with a heavy dough or other difficult to mix substance. The best way to establish the cause will be to open the head up and check the gears for signs of damage.
SOURCE: KitchenAid® Professional 600? 6-qt. Bowl-Lift
nice machine!! enjoy using it. I assume you have no problems with it since no problems are described!!
SOURCE: Bowl Lift
I had this problem and fixed it with some grease on the bowl lift lever. I used coconut oil for the grease as its obviously food grade. I greased the exterior which was the cause of the problem and the inside of the bowl lift lever. To get to the inside you can flip the mixer over (unplug it first) and remove the base with 3 screws to improve access. If further disassembly is reqired the C clip can be removed from the bottom of the mechanism and then slide the spring out. The bowl lift stand then comes out (you need to remove one screw if it catches) and you can easily reach inside. When putting it back together get someone with small hands. The C clip is easy to drop in the machine and easily lost.
