SOURCE: reinstall windows xp pro
Ok firstly, you will need to get rid of Vista all together before you can Install XP, Use a partition program to do this, You can find a bunch just by typing partition software into google, Delete the main partition that windows is on, Then create a new partition, then format that partition as a Primary partition, I always use the NTFS format just for stability and it can handle larger files than a 32 Bit partition, when you have done that then you need to get a bootable windows xp and I think you have that if set up is starting but hanging. Just go through the windows setup and you will be done. BE AWARE that you will loose everything thats on the drive by doing this so backup what you want to keep before you start, Always an idea to get the XP drivers for the system as well, The Vista drivers WILL NOT work on an XP system
Hope that helps.
If you run into problems then let me know and I will help you with it
SOURCE: genius videocam ge111 not install on windows vista
are you trying to install a software? or the cam itself? the cam is a plug and play so you dont neeed software normaly, and the thing about vista is that it does not like alot of programs that are made befor vista wa.
SOURCE: Vga and sound error
Go to the Dell website, www.dell.com, click on the support for my system link, input your Dell Service tag# and then download the vista drivers for your sound & vga. Install & you should be all set. Hope this helps.
SOURCE: i cant find vista drivers for dell optiplex gx270 pc
You can download the drivers from Dell WEB site, the support download page. Make sure you select your model laptop, better still, type in the Service Tag number, it is printed on the label on the bottom of the laptop. This will open the page where the specific drivers for your model laptop are located. Also make sure you select the Windows XP or Vista version of the driver for your Windows operating system.
Click on this link :-
http://support.dell.com/support/downloads/index.aspx?c=us&l=en&s=gen
SOURCE: how i have dell desktop optiplex 755, which
well you now need to go into my computer and click in the windows.old and you will see them there now you copy them across to your new setup and put them in the same folder you take them out of that should let you get everything the same as you had. the easiest way is to copy the folders DESKTOP, MY DOCUMENTS, and if internet is needed MY FAVOURITES but remember to put them back in the same place you got them from ok. hope this help and good luck
