Question about Dmm Exercise & Fitness
Where can I buy an elevation motor for a Keys model EC3500 treadmill?
4 Suggested Answers
6ya staff
SOURCE:
maxtreadmill
John Mazmanian
  • 832 Answers
SOURCE: Elevation is elevating in the wrong direction
Unless this unit was physically re-engineered,either the rear end incline on some models or from the front depending on the mechanism look closely when you fold it up chances are you will be able see that mechanism thru the bottom cover slot made bigger for the rear wheels to move.
Posted on Apr 11, 2010
sadha babu
  • 33 Answers
SOURCE: my sole f63 treadmill shows an elevation error and
pls do re-calibration
Posted on Dec 11, 2010
ercupa190
ernesto cuadra
  • 12223 Answers
SOURCE: squeek in motor of 6110p treadmill
Dear Sir:
The motor you can be oiled . But see the next instruction.
RUN THE SOFTWARE CALIBRATION FOR Easy diagnose and troubleshooting , see the instruction under the Hood of Motor, and follow the step or user manuals. Inspect the 1) Potentiometer + gear of the same Pot ( lubricate very slight).
sincerely. God bless you.
ernesto cuadra
managua, nicaragua. c.a.
Posted on Feb 16, 2012
Testimonial: "thanks for the help!"
My vision treadmill T9800HRT when start shows speed stall and error 7
please see the 2 alternatives for error 7.God bless you
E7- 1) Alternative Elevation Motor
1)Cause: Elevation Motor not moving Solution:Check Elevation Motor connection
2)Cause: Elevation Elevation Motor screw binding Solution: Clean screw and lubricate
3)Cause: Elevation Motor Motor out of Range Solution: Check motor out of elevation
4)Cause: E-Motor Potentiometer: Solution: Replace Elevation Motor
2)Alternative:
Display Doesn't Light Up: a)Cause: On/Off switch Solution: Test unit is turned on b)Cause: Insufficient Power Source Solution: Plug dedicated120V, 20Amp Outlet
c) Cause: Line Cord Damaged Solution: Replace Line Cord
d)Cause: Fuse Solution: Check Fuse on MCB
Sep 20, 2013 | Vision Fitness 2011 Vision T9800 Hrt...
My vision treadmill T9800 HRT when start shows speed stall and error 7
please see the 2 alternatives for error 7. God bless you
2)Alternative:
BH fitness pioneer start treadmill- flashing E7
see this error has 2 alternatives. proceed according. God bless you
2)Alternative:
Jul 15, 2013 | Exercise & Fitness
Endurance xt3300
follow the steps and fix it. God bless you. You have 2 alternatives with this error.
2)Alternative:
Jun 19, 2013 | Exercise & Fitness
Ror message 7 on Gofit silver model. Treadmill has just been relocated to another house
please proceed according:
see the diagrams attached and fix it.God bless you
ERROR CODE # 7
2)Alternative:
d)Cause: Fuse Solution: Check Fuse on MCB1_18_2013_6_30_23_pm.png1_18_2013_6_30_42_pm.gif
Jan 18, 2013 | Exercise & Fitness
I have a tunturi t40 treadmill an error code e7 appears And it cuts out after 5 seconds have tried to calibrate the elevation motor but it won't stay at 9 mm gap when it powers up the gap closes
please test the 2 alternatives for error 7. God bless you
see the diagram attached.
ERROR CODE # 7
2)Alternative:
Jan 08, 2013 | Tunturi T40 Folding Treadmill
Treadmill Protec Forerunner 3000 E 7 light on (mother control board FH-3545C-E, VER:B2)
Step 1:
you will have two alternatives:
ERROR CODE # 7
2)Alternative:
see the block diagram+additional diagrams for troubleshooting and fix it.
God bless you
Step 2:
1_4_2013_6_15_26_pm.jpgelevation motor diagram
Step 3:
treadmill motor control board diagram
Jan 04, 2013 | Sportcraft Exercise & Fitness
Treadmill KETTLER PACER error code E7, what I have to do?
see the next steps and fix it. God bless you
ERROR CODE # 7
2)Alternative:
Nov 28, 2012 | Kettler treadmill Pacer
Treadmill KETTLER PACER have error E7 when starting run. How to eliminate it?
see the following indications and fix it. God bless you
ERROR CODE # 7
2)Alternative:
I HAVE POWERTREK STRIDER IS NOT WORKING WHAT WILL I DO
see the next causes and remedy and fix it. God bless you
ERROR CODE # 7
2)Alternative:
Nov 13, 2012 | Treadmill Doctor Nordictrack Powertread...
Exercise & Fitness Logo
35 people viewed this question
Top Dmm Exercise & Fitness Experts
Treadmill Repairs...
Tom Chichester
ray gallant
Are you a Dmm Exercise and Fitnes Expert? Answer questions, earn points and help others
