I'm sorry but, no you need the remote. The cheapest way to go is usually to check everyone's favorite auction site for the remote for your model number combo player. There are also some sites that specialize in "replacement remotes" but , are usually more expensive. I hope this is helpful to you. Bobya.
With nothing else connected all you should have to do is select "DVD" and open and place a disc inside then hit play etc---original remote may be needed if no buttons on the unit.
It is a common problem with any universal remote controls. Try an other code for your device. Select one code which has maximum functionality. Than is the only thing have to do.
If the buttons on the case are working but the buttons on the remote don't then it's clearly a fault with the remote.
Each button in the remote is made out of 2 wires on the electronics board that are joined by a small patch of conductive paint situated on the rear of the rubber button. If something gets in there, like water or dirt or the patch flakes out, the contact is no longer made and the button no longer works. The remote will have to be dismantled by popping the clips on the periphery with a sharp tool, the rubber strip holding the buttons will have to be washed and the board wiped clean. If the buttons still don't work after that then the remote is dead, you will have to get another one.
Make sure the batteries in the remote are working (they go in the back of the remote at the bottom).
Turn on the DVD player with the power button on the DP300 itself (lower left). Open the dvd tray either with the remote (press open/close button, upper right) or with the button on the DP300. Put a DVD in the tray and close it with the remote or the button on the DP300. The DVD should load.
Use the arrow buttons in the centre of the remote to select choices from the onscreen menu of the DVD. Press Play (centre of the 4 arrow buttons) to activate the choice you want. For example, if you want to play a movie, use the arrow buttons to go up or down until "play movie" is selected, then hit PLAY, and movie will play. If you want to choose a scene/chapter of the movie, use arrow buttons to go up or down until Scene Selection or Chapter is selected (highlighted), and press PLAY. This should bring up a list of the scenes or chapters. Use the arrow buttons to select the one you want, then hit PLAY, and that scene should play.
If the DVD tray is taking less than 20 seconds to operate, there is likely no problem. If it is taking more, there may be. I think the mechanism that opens and closes the tray is often the first thing to stop working on DVD and CD players.
You can probably use the front panel buttons (STOP PLAY OPEN/CLOSE etc) manually, the only thing you cannot do without the remote is access certain DVD menus, including subtitles/language/special features etc. You can always obtain and use a universal remote for basic menu functions later on if necessary.
To play a DVD movie without the remote, simply load your preferred disc, wait for the player to finish reading its contents, then to skip copyright warnings and/or the 'play movie' menu screen, press STOP, then PLAY, or simply press PLAY button where 'play movie' (or whatever function) is highlighted in the menu. These buttons should be on the front of the main unit. Doing this should encourage the player to detect the appropriate title (the movie) and play it (basic playback operation may not be possible with some DVD releases due to the numerous interactive menus and title pages, such as film trailers).
If basic manual operation is not completely possible with some DVD titles, consider a universal remote for your player if you have either lost your original, or the player was purchased/received without one. Such remotes are relatively inexpensive to purchase, and are available just about everywhere.
I can view channels but cannot view a DVD from the TV/DVD Disney Princess Combo. Only see static on the screen with no sound. I wonder if I need to change the input select to view a movie but cannot find a button on the TV or remote control. I have a 6 button remote which I am sure operates the DVD and another remote with 39 buttons I thought would operate the player as well as the TV. However, so far only the player functions from it. The buttons only have small pictures without words which sometimes leaves some question about purpose. This is a second hand unit. I do not have a manual. It did play movies at first. I think the trouble may have started when I programed cable channels. Any help will be greatly appreciated
When I try to play a DVD, operation seems normal, the unit makes a slight noise like the disk is rotating and "Loading" is displayed. Then after about 30 seconds the message "No Disk" is displayed. Then just the Polaroid screen is displayed. I have lost the remote control but surely the unit will play using the front panel buttons. One thing, only the remote is named as having a Setup Button in the manual but the unit has no such button.
General
Problems Player won’t work (locks up) •
Try unplugging the AC power cord and plugging it back in. •
Reset the DVD/VCR: on the front of the unit, press and hold the STANDBY/ON
button while you press and hold the STOP button—wait at least 3 seconds before
you release both of the buttons. You’ll need to set up your menu preferences
because this Reset Procedure returns the DVD/VCR’s menus to the factory default settings and also erases the
contents of the Disc Library.
