Hi Brittany Emerson tv from Black and white to color
This does not describe a fault and what you are trying to achieve.
If someone is going to put the time and effort into answering your problem then you must take the time to put some detail into your question.
39L1350U) and am trying to hook up the DVD player. ... My DVD player only plays in black and white ... My DVD player is an old Sony. .... Was using and S-Video connecting cable to the TV. ... suggested to use VIDEO instead of COLOR STREAM, I changed that in the TV menu, plug the red and while at the back of TV where ...
Jul 14, 2014 - I hooked up my DVD player and I have no color. ... you need to use the connections on the left side of the TV or on connections on the back. .... is turned on, which can cause this black and white image issue you're having. ... If the Player shows correctly on a different TV with the same hook up, and different ...
Check its picture settings first. If color intensity is decreased to Zero, there will be no color to picture. Get into its picture set up option, and check this first. If it is found normal, check the system settings, such as PAL, SECAM, NTSC etc. If there is an option to select the system settings to "Auto" (if your TV is a multisystem one, this option will be there), select this option"Auto".
If nothing of above said help you, contact any service technician. Gopakumar Gopalan Google
Did you find a solution, I have the same problem with my Emerson TV. Same color pattern loop. Tech support was no help and TV is just 3 months out of warranty.
you have to change color system of dvd(ntsc, pal,) normally dvd remote will p/n button..press it to change color system,,otherwise u have to change color system of ur tv
Make sure that the color control level is set to the default or 50% to start with. This should be in the Video menu.
The colour for the tuner and for the encoded base-band video uses a circuit area called the colour demodulator. It is possible that this cirucuit area has failed and needs servicing.
The problem you describe is component failure in or arround the Horizontal Output Transformer section usually.. I would take it to the shop & get a "Quote" B4 proceeding.. there aint much ya can do yaself really without a Service manual etc.
