Question about Panasonic Lumix DMC-FZ28 Digital Camera
Firmware updates fz38 - Panasonic Lumix DMC-FZ28 Digital Camera
I have a panasonic FZ38 camera. I'm trying to use
I'd take the batteries and SD card out for a day then try powering it on again. If it asks you to set the time and date when you turn it back on you did it long enough to clear the memory.
Second option is to try another SD card.
Last hope is slide that little lock slider on the side of the SD card and try it in both positions.
Your card may also be full.
Regards
TickMagnet
Aug 15, 2011 | Panasonic Cameras
Sansa/Sandisk m240/1.GB Firmware information. I would like to be able to download firmware software for this device. If not a link for the older version of the firmware. Or maybe some suggestions for...
good day sir hope that this will help you to your problem....
What is a firmware, and what does a Sansa Firmware Updater do? Firmware defined
Firmware is the software code that powers your Sansa player. SanDisk actively and periodically updates the capabilities, functionality, and reliability of your Sansa player through this firmware. For optimal experience with your Sansa player, SanDisk recommends that you update your firmware with each new release.Firmware updates are free.
The Sansa Firmware Updater is an application designed to deliver the latest firmware, software support, User Manuals right to your desktop.
Download Sansa Firmware Updater.
Sansa players supported by the Sansa Firmware Updater:
- Sansa c200 series
- Sansa Clip / Clip+
- Sansa e200 series
- Sansa Express
- Sansa Fuze
- Sansa Fuze+
- Sansa View
Supported OS:
Windows 7, Windows Vista, Windows XP, Windows 2000 SP4
NOT supported:
Mac & Linux
NOTE: Administrative access is needed on your PC to run the Sansa Firmware Updater.
if this help you please rate me sir thanks you...
Jun 05, 2011 | Computers & Internet
Suddenly we can't connect to our Mac. It worked fine before, but all of a sudden it's stopped. restarted the computer checked the connections, but nothing. it's just stuck.
As a Mac user I don't bother with the camera software nor do I download using the camera. Best way to work around the software and firmware incompatibilities is to purchase a memory card reader. The Mac looks at this as an external drive and you can open the memory card see the thumbnails copy and paste the files into a folder in "Documents". Don't know what OS you have but there is a viewer that you can open to see the pictures and if you were successful in loading the camera software you can use it to do your photo editing. My suggestion would be to invest in a Photoshop program. The reason I'm suggesting this is Photoshop is the "industry" standard and by having a multiple port card reader you can change cameras, even memory card types without the hassle of programming compatibilities. Now as far as this "all of a sudden it stopped" what has happened is there was an auto update which basically made the camera download non compatible.
I don't know how old your Panasonic is but there is a lot of people still using "older" digital cameras that work just fine but the computer updates and software is leaving them in the dark. The Mac will work great with the card reader (I'm using Photoshop CS3) and a Photoshop program even if you update the OS. People that are using PC and upgrade to Windows 7 are just dead in the water when it come to the camera software. Oh and another thing that's happening is memory card capacity at one time a 2gig was huge and the camera firmware was compatible with 2gig memory but, if you try putting a larger memory card in say a 4gig the camera won't accept it. I was fortunate with a couple of my Pro cameras where I was able to go onto the manufactures web site and update my cameras. Cheers have a great day ;-)
Mar 04, 2011 | Panasonic LUMIX DMC-FZ38 (DMC-FZ35K)...
How to upgrade the software for DMCFZ35K Digital Camera
if you are referring to the firmware of the camera ..this should be available on the support site from Panasonic..(Lumix)...and on the download area choose firmware and see if they have any updates..
If you are talking about the driver for Pc connection ..this will be in the driver area,, but usually Lumix do not need any drivers but work on Microsoft operation systems directly ..
To get on the support site ..just type Lumix support on the search engine ..and see the result..
Dec 24, 2010 | Panasonic LUMIX DMC-FZ38 (DMC-FZ35K)...
Canon IPF8000..... i need to override the "ink
Before removing the used print head, be sure to update the printer?s firmware version with the included CD-ROM. An error message will be displayed on the printer?s display when the new print head is installed without updating the version. In this case, re-install the used print head and update the firmware version.
Updating the firmware
1. Turn on the power of the printer. Check that the printer is online.
2. Run the file setup.exe in the FirmUpdate folder in the CD-ROM. [GARO Firmware Update Tool] will be installed.
3. Run [GARO Firmware Update Tool] from Programs in the Start menu.
4. By following the instructions, update the firmware version.
2. Select the OS89 folder in the FirmUpdate folder in the CD-ROM, and run [GARO FirmUpdate]. [GARO Firmware Update Tool] will be installed.
3. Run [GARO Firmware Update Tool] from [Applications] - [GARO Firmware Update Tool] folder.
2. Select the OSX folder in the FirmUpdate folder in the CD-ROM, and run [GARO FirmUpdate].
Precautions when updating the firmware version
- Use [GARO Firmware Update Tool] after checking that the printer is online.
- Do not turn off the power of the printer while firmware data is being transferred.
- If the printer?s firmware is already the most recent version, the Status of the target printer will be displayed as ?Update Finished? when using [GARO Firmware Update Tool].
Techbelkin
Dec 13, 2010 | Canon imagePROGRAF iPF8000 Printer
Lumix FZ38 I have recently acquired a Lumix FZ38 Camera. It takes excellent photos and videos. I wish to edit and merge the AVCHD (.mts) files, but he supplied software does not allow this. I have Corel...
Use the windows movie maker for windows 7 downloadable from microsoft.com's download site.
It's a pretty good program for splicing together video clips into one large one.
Aug 03, 2010 | Panasonic Lumix DMC-TZ3 Digital Camera
Why haven't you found solutions for the posts above???
Hello joe_east,
The Belkin Router's software (firmware) can be occasionally updated. To check for new updates, go to the Belkin Router Setup page http://192.168.2.1/ . The following choices will appear to update firmware and save current settings:
•Select Firmware Update (Near the bottom of the left-hand panel)
From time to time, Belkin may release new versions of the Router's firmware. Firmware updates contain improvements and fixes to problems that may have existed. Click the link below to see if there is a new firmware update available for this Router.
•Firmware update Options:
Firmware Version > #.##.##
Check for New Firmware Version > [Check Firmware]
Update Firmware > [Enter file name/Browse]
[Update]
•NOTE: Please backup your current settings before updating to a new version of firmware. Click Here -> http://192.168.2.1/system_c.stm to go to the Save/Backup current settings page.
•Save/Backup Settings
You can save your current configuration by using this feature. Saving your configuration will allow you to restore it later if your settings are lost or changed. It is recommended that you backup your current configuration before performing a firmware update.
*Saved File name is user.conf*
If this solution is helpful please click a thumbs-up rating below.
Have a great day,
martyshaw152
Jul 04, 2010 | Belkin (F5D7230-4) Router (587009)
I seem unable to shoot any more than 4 frames per sec fz38 burst
You need a card with a fast write speed to achieve 10 frames per sec.
Jan 31, 2010 | Cameras
USERS MANUEL in English needed
Go to the support section of the Panasonic website and enter Lumix FZ35. That's the same camera in the USA. If your camera comes in a color, you will need to add the letter of your color.
Jan 10, 2010 | Panasonic Lumix DMC-FZ30 Digital Camera
Pic and vidos
I believe all you need to do is go to SanDisk's website, under Downloads, then download the Firmware Updater: http://www.sandisk.com/Retail/Default.aspx?CatID=1376
After installation of Sansa Firmware Updater
* Please make sure your Sansa player is in MSC mode before plugging it in.
* Plug in your Sansa player and it will automatically check for updates.
Common questions about the Sansa Updater
Q: What does the Sansa Firmware Updater do?
A: The Sansa Updater is an application that checks for the latest firmware updates then downloads and installs the firmware to your Sansa device. The Sansa Updater is NOT a firmware.
Q: Why do I need to install the Sansa Firmware Updater to download "firmwares"?
A: Once you install the Sansa Updater, you don't have to worry about which firmware to download for your device. Sansa Updater downloads and installs the right firmware for your Sansa device.
Q: Do I need to install the Sansa Firmware Updater everytime there's a new firmware?
A: No, once the Sansa Firmware Updater is installed, future firmware updates are done by just plugging in your device.
Q: What does a "firmware" do?
A: Firmwares contain miscelleneous bug fixes and enhancements.
Q: Which Sansa players is the Sansa Updater compatible with?
A: The e200, c200 and m200 series
Q: Should I "Open","Run" or "Save" when i click on "Download Sansa Firmware Updater"?
A: "Open" and "Run" would automatically start installing the software,. "Save" would save it to your computer and you can run it in the future. We suggest you "Open" or "Run" the installer.
Q: How to change to MSC mode:
A: On your Sansa device, press "menu" and go to "Settings" then "USB" choose "MSC"
Q: How to check for firmware version?:
A: On the e200 and c200, press "menu" and go to "Settings" then "Info"/ "System Info". For m200, press "menu" then "Information".
Nov 12, 2008 | SanDisk Sansa e260 MP3 Player
Panasonic Lumix DMC-FZ28 Digital Camera Logo
220 people viewed this question
Top Panasonic Cameras Experts
Ekse
rajiv6089
Level 1 Expert
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
