SOURCE: Mitsubishi WD-52525 Lamp ballast
Contact Mitsubishi Parts themselves, 18005537278. They are very friendly.
SOURCE: Ballast is loose and not connecting to the new lamp . . . Any suggestions?
whats a bulb? whats a ballast?
try calling an expert for I don't even know what you mean.
SOURCE: Looking for a ballast part number and price Mitsubishi WD-C657
encompass.com or parstore.com is a good store parts.
Just provide model number tv.
Thank you
SOURCE: Mitubishi WD 62725 - Ballast Problem??
Could be the FMT pcb or the Dm pcb board you should check the caps on them and replace any faulty ones.
SOURCE: Mitsubishi 52525 TV Red Lamp LED
340v should be on power pwb plug PL on the 1 and
5 (GND) pins for the ballast. and the ballast plug CN should also have the 340V with pin 1 of that plug being GND nd pin 3 should have the 340V If the PL plug on the power board is low the power pwb has a problem most likely the doubler circuit. If CN plug voltage is high say 360V the ballast is suspect.
