Microids Still Life for Windows Logo
A
Anonymous Posted on May 03, 2014
What is Still life error can't create renderer
Deepu Amalan
Level 2:
Novelist:
Scholar:
  • Expert 167 Answers
  • Posted on Sep 15, 2015
Deepu Amalan
Expert
Level 2:
Novelist:
Scholar:
Answers
167
Questions
0
Helped
69911
Points
274
Your Display may not be compatible with the game or its native resolution.
update graphics card and its drivers. along with directx dot net framework etc.
How do I recover from an "Export failure render error 0/45543@00:00:00:00"?
you need to create an image of the file that you want to put on dvd
5helpful
Export:error:real time c:\users\owner\appdata\local\microsfolder\render\my movie 848e009f\alternate\render\my movie 848e009f\dvd\studiosequence\temp' Help - what does this mean? What should I do?
Hi and Welcome,
If you are experiencing Export Errors using Studio, the following FAQ should help:
1. UPDATE TO THE LATEST PATCH:
Click here for the latest Studio 12 patch
There is no patch available at this time for Studio 14
2. ENSURE BACKGROUND RENDERING COMPLETES:
Allow the green bars that appear over clips that have had filters, transitions or other effects added to complete before going to the Make Movie stage.
3. ALWAYS REINCODE ENTIRE MOVIE
If after installing the latest version of Studio, the Export Error persists and you are attempting to create a DVD, then in Studio click on the Setup pull-down menu and select Make Disc. On the top portion of the Make Disc tab make sure there is a check in the box for the setting "Always re-encode entire movie", then click the OK button. Create the DVD again.
4. DELETE AUXILIARY FILES
Delete the auxiliary files before rendering. To do this, go to File >> Delete Auxiliary Files. This will bring up a window to chose which auxiliary files will be deleted. Select the option to delete the files for the current project. Once this is done, try to output the project.
Printhead Error is displayed and therefore rendering the machine unuasable. Do you have any suggestions for a fix?
Replace with new printhead if the print head is past it's service life. If not past it's service life when you get that error message press the online button and it should print fine.
1helpful
Flip Ultra is not recognized by FlipShare!
make sure all your computers drivers are up-to-date. If they are then make sure you have the latest service pack for your particular OS.
3helpful
2answers
Flip Ultra HD Error upon pluging in the camera
I got around this error by moving my library to another location. I created a new folder, then went to Preferences->Library and chose a new location (the new folder I created). Flipshare moved all the data, and after restarting the program the problem disappeared. Not a great solution, a workaround.
7helpful
5answers
Corel x2 problem: Unable to Load Library when sharing to VCD
Hey everyone, I faced the exact same, excruciatingly frustrating problem. After a quick search, I found forum threads telling me that when Corel Video Studio was modified to suit Vista, something about its 3D transitions got messed up.
So, if you face this problem while using Corel Video Studio on Vista, check that you have removed all 3D video transitions and try rendering again.
6helpful
2answers
Counter-strike 1.6
see if your mouse has left hand properties
control panel set up mouse OR
If you cannot switch your weapon to the right-hand, please go to your advanced video options and change the renderer to either OpenGL or Direct3D. The software renderer does not support right-handed models.
You can select left or right-handed models by typing the following command into the Console:
  • To use your left-hand: cl_righthand 0
  • To use your right-hand: cl_righthand 1
You may wish to create a userconfig.cfg file with the cl_righthand 0 command if you would like to keep the left-handed setting. Please follow these instructions to create a user.cfg file:
  1. Locate the subfolder in your game folder that holds the config.cfg file
    For example, you can find the config.cfg file for Counter-Strike at [Steam installation directory]\steamapps\[your Steam account name]\counter-strike\cstrike\config.cfg
  2. Create a new text file in that directory called userconfig.cfg
  3. Open the file with Notepad and enter cl_righthand 1 (to use the right-handed model) or cl_righthand 0 (to use the left-handed model)
  4. Save the file
  5. Launch the game to test the user.cfg settings
1helpful
VPU Recover - Hardware Rendering disabled - using software instead
Go HERE and download the original version of the video driver and install it.
You may want to use an ATI driver from here but it looks like there is not a 9200 mobility driver ???
IF the problem continues, I suggest you use this LINK to a guide to remove the driver manually before installing new one.
WARNING this includes editing the registry so take extreme care to do EXACTLY as stated.
It would be worth creating a restore point PRIOR to startin so that if necessary you can get back to where you are now if it all goes pear shaped.
5helpful
3answers
?Error? Cannot render audio capture stream
Download intervideo windvr and your problems are over!
Top Microids Video Game Consoles & Games Experts
MegaByteMe
MegaByteMe
Aron
Are you a Microids Video Game Console and Game Expert? Answer questions, earn points and help others
