SOURCE: took screws out of blades now won't move
there is something to do with the balancing of the blades
it would of been better to send them in to be sharpend...they charge 10 bucks for this service in australia
best send the blades in
SOURCE: Oster clipper blades get red hot and won't cut.
see this link, its for the A5. The A5 is the animal version of the 76.
http://www.peasridge.co.uk/clipper-advice/clippers-products-oster-a5.shtml
I dont know what model you have, but if you need schematics for YOUR model see this link.
http://www.clipperrepair.com/parts.htm?brand=8
SOURCE: pet hair clippers blades move but dont cut.
Do not use regular oil on the clippers.
Instead use OSTER KOOL-LUBE.
We were told the blades become to hot with regular lubricating oil such as 3 & 1.
We bought some KOOL-LUBE from our neighborhood PetsMart and it corrected the problem on both sets of our clippers (one heavy duty clipper for dogs, one regular clipper for humans).
Here is a link to KOOL-LUBE on the PetsMart web site:
http://www.petsmart.com/product/index.jsp?productId=2752831&utm_source=googleproduct&utm_campaign=2011235&utm_medium=cse&mr:trackingCode=A9C8D151-4519-DE11-B0EA-001422107090&mr:referralID=NA
Jan
SOURCE: Oster A5 clippers blades stop moving when put into
How old is your clipper, Oster clippers need to be adjusted for more power and speed, also what clipper blade are you using to cut the horse hair and how long is the horse hair, Also the blade may not be sharp, some new blade are sharp maybe defective.
SOURCE: oster clippers blade
John! No Problem!
First put the bigger of the two blades witht the size/number facing down, put the cutter on top. (with the side with the flat side of the teeth facing down) Then put the tongue guide inside the tension spring, make sure the tension spring rail is on the tension rail and place them on top of the cutter. To see which bits these are go to: http://www.sheareaseltd.com/clipper-blade-sharpening/clipper-blades-the-parts
This picture whows the front and back, it differs slightly from your blade, but its same meat different gravy!
Hold all this together with your finger and thumb, flip it over and scre the whole lot together!
