Feb 20, 2011 - These codes in your (made-by-Samsung) Maytag washer might pop up during the ... In fact, the E3 error code means that the Machine Control wants to make the motor spin but won't do it because it's getting a weird reading from the tachometer.... MAH6700 and MAH8700 models (they use the same motor).
May 15, 2015 - Samsung uses the 3E error code to indicate a drive motor tach fault. ...If you're handy, you can fix your Samsung front load washing machine error code ....My samsung frontload washer shows e3 and the drum does not turn ...
There is no error code ee Could it be 3E or E3 if is 3E then it means "High current detected" if its E3 then it means "Motor not running properly" here is the link to the manual I checked all manuals starting with the model number Wf337AA the error codes are all the same. http://downloadcenter.samsung.com/content/UM/200710/20071010083409359_WF337A-02440A-06[1].pdf
Well the error code 3E means that the overcurrent is detected at the moter.
Please check it if you have some overcurrent problem!
Thanks!
mannu_rakesh
