Question about Westinghouse LTV-32w1 32 in. HD-Ready LCD Television
My Westinghouse 32 inch With DVD has color problems. It turns purple in many parts of the screen. Any ideas to fix it?
6ya staff
SOURCE:
Jason Morris
  • 362 Answers
SOURCE: Blank screen when tv has been on for 10-20 minutes
Hi jilanfa00,
I am happy to help, we need to check the backlight inverter.
  1. Turn tv on and get to a point that you have audio.
  2. Take a flashlight and shine it on the screen.
  3. Look very closely at the screen for a very dark video image.
If you see an image you have a bad inverter, you should be able to replace it yourself. I can walk you through in chat. Let me know your findings. Lone99star
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jason_77a19afa8d604dee
Posted on Jan 20, 2009
jose martinez
  • 159 Answers
SOURCE: bright colors bleeding onto picture
if you tried adjusting all parameters in the menu and anything you do is not resolving it, go into any workshop to have them replacing the main board. It looks ugly this idea but now days this kind or repair is posible and the board is "affordable". find any workshop close to your area. The reason of this idea is because the main board controls all parameters in the tv and the other part who we can blame on is the screen itself so if the tv is repairable (economical to repair) the workshop sure it would tell you.
Posted on Apr 14, 2009
dave1645
Dave Naylor
  • 834 Answers
SOURCE: my 32 inch westinghouse lcd tv's screen turned pink when on
your T-con board is failing you need a tech to replace it about a 150 dollar job
Posted on Nov 18, 2009
budmrtn
Bud Martin
  • 11361 Answers
SOURCE: after about 2 or 3 hrs my Westinghouse 32
Does it look like this? http://s807.photobucket.com/albums/yy352/budm/LTV-32W3HD/
You may have LCD controller board overheating problem (the pictures show the board with shield removed)
Try cooling it with small fan blowing at the vents.
Posted on Mar 29, 2010
Anonymous
SOURCE: westinghouse 32 inch screen goes blank
replace capacitor c162 on power supply
power supply was a delta electric dps210ep-2c rev01
reheat any solder joints that don't look 100% as well .
such as c310 .
this is a known working fix . try before you buy a supply .
Posted on Apr 15, 2010
How to fix Westinghouse WD32HD1390 tv when black vertical bar show up on display?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Aug 19, 2017 | Westinghouse Televison & Video
Can i use a westinghouse screen to replace a vizio screen
Kenneth,
Please re-post in Electronics > Televisions & Video
The only thing I can state, is look at the manufacturer code on the back if the screen, (Westinghouse), and see if it is a replacement for the Vizio's screen.
[This is the Laptop PC category]
Regards,
joecoolvette
Feb 25, 2013 | Vizio 32" Class LCD 720p 60Hz HDTV with...
Purple yellow green lines on the right side of the screen
Try to play dvd if the lines comes out you have cable box connection problem, if still there you have problem in t-con board (inside of TV).
Just replace it to fix the problem.
Dec 10, 2012 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Sound but the screen on my westinghouse 32 inch flat screen is solid lime green
By "sound but the screen on my westinghouse 32 inch flat screen is solid lime green" Do you mean that you have sound but the screen is green? If yes it means that an analog signal is being fed to a digital input. Did you recently change the input cables at the back from one port to another? If not then please describe what are colors of the cabels you are using(Yellow, Red, White or Red Blue Gren etc.,) and what port they are connected to so that I can tell you whether its a problem with the connections or the tv itself.
Jun 15, 2011 | Westinghouse 32" Flat Panel LCD HDTV
Westinghouse 32 inch lcd hdtv model # VR3209DF. screen problems
Ur tv the Tuner board,that where the coalax broscast signal cable come in to this board.This board is starting to have problems.
Jun 07, 2010 | Televison & Video
My 32 inch westinghouse lcd tv's screen turned pink when on
Nov 18, 2009 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
Bright colors bleeding onto picture
Apr 08, 2009 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Intermitant color bursts of red, green, purple
Kevin,
for the color problem,most likely you do have problem with loose contact of components from C-board ( small board connected at the back of CRT "picture tube" which drives every color and size of the screen)if you have knowledge with soldering electronic component parts, resolder this board and also check main board for possible loose contact.
cheers,
mark
Feb 04, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Westinghouse 32 inch screen goes blank
such as c310 .
Dec 25, 2008 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Dark Vertical Stripe on Right Edge of Screen
I experienced the same approx. 1/2" vertical stripe on a Viewsonic vx1945 and ATI Radeon x1050 video adapter on Vista Business SP1, but the stripe appeared along the left edge of the screen, instead of right edge. I then temporarily decreased the monitor resolution, and the stripe went away. I then increased the monitor resolution back to its original setting, and the stripe did not re-appear. So, that was the 'fix' in my situation, hope this helps.
Dec 11, 2007 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
Westinghouse LTV-32w1 32 in. HD-Ready LCD Television Logo
16 people viewed this question
Top Westinghouse Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
