SOLVED bleach and fabric softner dispenser problem Kenmore Elite HE3...
Please, refer to the above link.
SOURCE: DARK CLOTHES END UP WITH BLEACH DOT STAINS
SOME BLEACH DISPENSERS USE COLD WATER TO FLUSH THE BLEACH FROM THE CUP. CHECK THE COLD WATER FOR GOOD PRESSURE. IF THERE ISN'T GOOD PRESSURE, REMOVE THE COLD WATER HOSE FROM THE MACHINE AND CHECK THE SCREEN INSIDE THE VALVE WHERE YOU REMOVED THE HOSE. PUT THE END OF THE HOSE IN THE TUB AND TURN IT ON. CHECK FOR GOOD PRESSURE. CLEAN THE SCREEN AND RECHECK THE WATER PRESSURE AFTER REINSTALLING THE HOSE AND TURNING ON THE WATER. IF YOU STIL HAVE POOR PRESSURE REPLACE THE VALVE.
SOURCE: bleah dots the exact size of holes in drum are on my dark clothes
It is likely the bleach tray door is not closing all the way after a bleach load... then being distributed on your clothing in subsequent loads.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
SOURCE: bleached out streaks on my clothing. After
Hi from retired Englishman in SW France @ 16:16 Mon afternoon.
Yes- I have a POSSIBLE solution but it depends on some answers-
I do not know your exact model- does it have a specific container for bleach or is the bleach poured into one of the powder/fluid/ conditioner trays?
If the latter, have you removed the tray and thoroughly cleaned it? If not it is possible that not all of the bleach is siphoning out properly because of a (partial) blockage. A similar thing happens to many people with the conditioner/softener tray. Because it is liquid the tray cannot have a simple open rear end else the conditioner would just pour in straight away so it uses a 'tube' down which the conditioner siphons/pours- providing that the tube is clear.
Trays are removed in a few different ways- pressing down on a plastic lip at the rear centre, pressing up on a catch underneath the tray OR by pulling then finally lifting the tray out.
Even if a blocked tray is not the answer, it is still worthwhile taking it out and cleaning on a regular basis. In the same way, particularly if you live in a 'hard' water area i.e. lots of calcium, it is well worthwhile running a sachet of proprietary anticalc powder/liquid through the machine- say every 3 months as I do!
I really hope the problem is the tray- though that might be too simple!
Best of luck,
John C
SOURCE: There is a loud banging
You need to open the cabinet and look at the suspension springs that support the tub. One of them may have broke or come loose.
