Panasonic Lumix DMC-FZ28 Digital Camera Logo
A
Anonymous Posted on May 04, 2014
I have a Panasonic Lumix DMC - TZ5 camera and a silicon power 4GB memory card. I am trying to view pictures taken but the camers screen says "thumbnail is displayed". What does this mean?
5 Related Answers
Anonymous
  • Posted on Dec 27, 2007
SOURCE: Message: Memory Card Error - Memory Card Parameter Error on 4gb SDHC card
I recently bought a DMC-TZ3 and have been researching memory cards. Several sites sell cards with the camera and list the card type. I would suggest buying one of these cards. Any cards larger than 2gb must be SDHC type SD cards. There appear to different types of SDHC cards, 1.0, 1.1 and 2.0. Check out Wikipedia.org for a description. 2.0 cards are not compatable for devices developed prior to 2.0 so that may be the reason for the camera problem. So far I haven't seen anything that states what type SDHC card the camera requires. I found a computer memory site that that sells memory that they say will work. There may be others.
http://www.mymemory.co.uk/compatible-memory/Digital_Cameras/Panasonic/Panasonic_Lumix_DMC-TZ3
Anonymous
  • 246 Answers
  • Posted on Jul 02, 2009
SOURCE: memory card locked
There is a switch on the SD memory card, slide the switch to unlock position before you insert the card into your camera.
More detail, see here How to fix a ‘card locked’ problem
Anonymous
  • 3006 Answers
  • Posted on Nov 28, 2009
SOURCE: Panasonic Lumix DMC-TZ4 black - memory card locked
Remove the SD card and slide the lock switch on it to the unlocked position. If it's already there then slide it fully to locked and then fully back again.
If this fails then you need to try another SD card to see whether it's a camera fault. If the camera is at fault then there's nothing more you can do other than to return the camera to Panasonic for repair.
Anonymous
  • Posted on Sep 24, 2010
SOURCE: I have a : panasonic Lumix DMC-LZ3 Digital Camera
Page 92 of owner's manual for DMC-LZ3 states "Do not use memory card larger than 2GB".
Anonymous
  • Posted on Dec 04, 2011
SOURCE: panasonic lumix Fz28, Error "Thumbnail is displayed"
What is the solution for this problem please. Thanks.
1helpful
I have Lumix dmc tz5. It is not recognizing the card. When I turn it on it says taking pictures with internal. I have reformatted card etc. still won't work properly.
With no card in the camera, go into the menu and find "format" and follow the directions to erase the internal memory. After that, your card should work properly.
Panasonic Lumix DMC-TZ5 able to download to ipod
Not directly. You can download the pictures to a computer, then upload them to your iPod. If you connect the iPod and the camera or its memory card, you can transfer the pictures from one to the other without storing them on the computer.
Camera: Panasonic Lumix DMC-FT1 Problem: Camera is not saving photos Hi, my camera started responding very slugglishly yesterday. I took a few pictures, and some of them wouldn't save. If I tried to switch...
Are you formatting the card in the camera as you're supposed to? Have you tried going into the menu and finding "reset" and followed the on-screen instructions? Do you have photos on the internal memory? If so, remove your card and format the camera to erase the memory.
2helpful
Panasonic Lumix DMC-TZ5 does not recognise my memory card
1. Go into the menu and find "reset"...follow the on-screen instructions. 2. With no card in the camera, go into the menu and find "format"...follow the instructions.. 3. After downloading any pictures from the card, insert it into the camera and do the "format" thing again. everything should work now. Remember, never use the computer to format or erase your card...always use the camera. Also, when removing the card from the computer, always use "safely remove hardware" icon at the bottom right of your computer screen.
Feb 16, 2010 • Cameras
3helpful
No, I am trying to download a copy of an owner's manual for my Panasonic Lumix TZ5 camera.
Here is your manual: You may need adobe acrobat or foxit reader for firefox to read it.
[PDF] DMC-TZ5 DMC-TZ4File Format: PDF/Adobe Acrobat
For Canadian assistance, please call: 1-800-99-LUMIX (1-800-995-8649) or .... Example screens displayed in this manual are for DMC-TZ5 model. DMC-TZ4: ...... MAIL THIS ORDER TO: PANASONIC SERVICE AND TECHNOLOGY COMPANY ...
service.us.panasonic.com/OPERMANPDF/DMCTZ4.PDF - Similar pages -
Copy images from pc to Lumix TZ5 SD memory card?
yes i m sure it would work if you use a card reader instead of using the camera directly connected.. in that case your memory card will just work as the usb hard drive and you can load anything into it..
Top Panasonic Cameras Experts
ZJ Limited
ZJ Limited
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
