I cannot turn the filter to get it out
SOURCE: Need to replace or remove
Called company. Have to eliminate water pressure by moving refrigerator out and turning off incoming water from line in back. They said water pressure was preventing cartridge cap from turning.
SOURCE: water filter replacement
I have the same problem. I did change the filter located on the bottom front panel of the refrigerator, but the red light is still on and NO ice. I can't figure it out and I know if I call a tech, its a 300.00 bill. Frustrated.
SOURCE: Removing the water filter and not replacing
Not with out re plumbing the unit underneath, it would be much easier to leave it in place.
SOURCE: Change water filter on Whirlpool side by side Refrigerator
Jill, download the instructions here:
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%202205958.pdf.
SOURCE: Refrigerator gushing water through ice maker filter
Filters themselves don't usually leak. Check full insertion of filter, cracked filter housing or cracked supply line.
