Turn on makes whistling noise no picture no sound
SOURCE: RCA HD52W59 HDTV.....will not turn on, makes a weird noise
you need a new flyback. Its a very easy repair you need flyback 259296 and you can get a new replacement at the following link and they explain step by step how to replace it. Heres the link
http://servicemanuals.vstore.ca/
SOURCE: RCA HDTV Model # HD52W59
I hope it is still under warranty,cause you need to either fix the problem with a A/V repair guy or return it and get your money back.
Don't fool around with it.
solutiondoct
SOURCE: TV makes aloud ringing sound
does the sound come from the speakers are from the back of the set. there is a small number of cases where the is oscilation in a coil.. the way we counter this at the shop is we dampen the coil with some silicon, not sure this problem you have. ll007 is the number on the coil.careful this television generates high voltage and retains this even unplug
SOURCE: rca d52w26 makes a long whistle noise
I have an RCA model D52W26. The green light comes on when powered on but turns off within seconds. No picture, no sound. Just a squealing noise then nothing. Any thoughts on a fix?
