Uniden GMR-325/2 2-Way Radio Walkie Talkie Dual Pack Logo
A
Anonymous Posted on May 05, 2014
What does tx mean on Wilkie talkies - Uniden GMR-325/2 2-Way Radio Walkie Talkie Dual Pack
Sparks Tech
Level 1:
Problem Solver:
  • Contributor 16 Answers
  • Posted on Aug 01, 2014
Sparks Tech
Contributor
Level 1:
Problem Solver:
Answers
16
Questions
0
Helped
5779
Points
15
TX means to "Transmit" or to broadcast from your walkie talkie.
2answers
Is there a product manual for this Wilkie talkie?
Google search your manufacturer make and model and the word manual. If one is available, you can find it in the search results.
How do I take a uniden Wilkie talkie off vibrate
model?
http://www.uniden.com/bin/venda?ex=co_disp-view&bsref=uniden&scat=twowayradios_mnl
When I press the talk button my Wilkie talkie turns off
Check your battery. This can be a sign of a bad or poorly charged battery.
Best regards.
Why are my Wilkie Talkies fuzzy
Fuzzy Wuzzy was a Bear,
Fuzzy Wuzzy had no hair
If Fuzzy Wuzzy had no hair,
then Fuzzy Wuzzy wasn't very Fuzzy,
Was He?
Support Cobra Electronics Corporation
2answers
What is the range for distance for my bellsouth walkie talkies model 2231
The manual says:
Channels Available - 22 Channels
Output ERP Power (TX) - 0.5W (FCC Maximum)
BatteryLife - 30 Hours (typical)
Range - About 2 Miles
Cx80 stuck in rx mode , power cycled, swapped batteries, changed channels, will only swtich to tx when ptt button pressed, otherwise always in rx mode, other radio from package works fine
But thats how a walkie talkie works, it stays in Receive Rx mode UNTIL you press the PTT button,, then it Transmits Tx, and when released it goes back to Rx, receive?
46helpful
One of my walkie talkie has an RX on the display and you can send but you cannot hear the other person. How can I remove the RX as that seems to be the only difference in them. Thank you
depending on what radio you have, they are programmed in different ways, rx means recieve signal
and tx means transmit signal, if you have a mode button, you will have to scroll through it until you
get to the menu that allows you to change the radio transmission. it looks like that radio is only
programmed to receive signals and not transmit. good luck!
1helpful
2answers
Walky talky
A walkie talky as we called them, back when we were younger - and hell we probably still do in some respects, hence the fact my friend still refers to her cordless phone as a "walkie talky" and the principals haven't changed that much.
The common old Walkie Talky or CB radio use what we call a half duplex, that means only one person can talk at a time. We are talking and listening on the same channel.
Cell phones are full duplex, meaning two way conversation, and this is simply listening on one channel whilst talking on another, so the basic principal is basically the same, just a little more sophisticated.
Walkie-talkie typically has one channel
CB radio has 40 channels.
Cell phone
can communicate on 1,664 channels or more!
I have included a link to a circuit diagram.
http://www.freeinfosociety.com/electronics/schemview.php?id=1870
There is also two links below, building the transmitter & receiver.
Transmitter: http://www.zen22142.zen.co.uk/Circuits/rf/2bjttx.htm
Receiver: http://www.electronics-tutorials.com/receivers/regen-radio-receiver.htm
Trust this helps, and please take the time to rate the answer given, thank you.
Top Uniden Radio Communications Experts
John
John
eradiostore
eradiostore
Grand Canyon Tech
Grand Canyon Tech
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
